trailer wiring
Old Oct 24, 2007 | 04:59 PM
2stroke's Avatar
trailer wiring
having trouble hooking up brake controler. i can only get the green light to come on when i stick my testlight on the blue wire coming out of the controler. why?
Old Oct 24, 2007 | 06:02 PM
2stroke's Avatar
this is a 12,000 lb dump traailer. there is a "brakeaway switch" that has 2 wires going to it that have been cut. is this why i cant get it to work?
Old Oct 24, 2007 | 09:46 PM
darkvader's Avatar
what controler, what test light
Clark
Old Oct 24, 2007 | 10:29 PM
PChouinard's Avatar
Your brake controller needs a complete circuit through the coils before you get a green light. When you use your test light, the bulb may be producing just enough resistance to fool the controller into believing you have brakes hooked up. The cut breakaway wires should not (at least I don't think they should) interupt your normal brake operation. I would look for a loose or broken wire between your plug and the grounded brake. Remember brakes are wired in series. Good luck..
wyododge
Jan 13, 2009 02:25 AM
Evildiesel
Jul 2, 2006 06:39 PM
charcoal600
Apr 30, 2005 02:34 PM
1320
Apr 9, 2004 09:33 PM
TPilaske
Mar 13, 2003 04:06 PM
