trailer on airbags
Old Nov 3, 2013 | 10:55 AM
  #31
chaikwa's Avatar
Originally Posted by Busboy
Perhaps but I recently saw 5 bolt wheels on 5200lb axles on a new tandem dump trailer, I was surprised too.
Just because someone has done it, doesn't mean they SHOULD. I see a lot of trailers come thru the shop that are illegal in some regard from inadequate tires to axles that are too light and even frames that are too small for the application. And usually by the time I see them, something has happened. Something BAD!
Originally Posted by 05CTDN8
That is an awesome home buildup. However, I feel there is a lot of disregard to safety in this setup.
1. The 2x12 are plenty for the weight if properly supported, but if there is any water/dirt/mold even with FWD or AWD you could be looking at a bad day quickly.
2. As stated, tying down just the front tires is not enough. At a minimum the rear should be tied at the wheels or using a frame to chassis chain with a tension buckle on it.
3. In the last photo I do not believe the weight of the truck is centered over the axles on the trailer and could remove weight from the 5th wheel. I have seen this before and at speed could result in loss of drive axle traction.
Once again, great buildup
I agree 05CTDN8. It IS a great build but there needs to be a bit more attention to the safety aspects. Securing the vehicles at all 4 corners in some form or fashion is required.
Old Nov 3, 2013 | 01:33 PM
  #32
Busboy's Avatar
Originally Posted by chaikwa
Just because someone has done it, doesn't mean they SHOULD. I see a lot of trailers come thru the shop that are illegal in some regard from inadequate tires to axles that are too light and even frames that are too small for the application. And usually by the time I see them, something has happened. Something BAD!.
Like I said I was surprised too. The trailer was not a home built but is made by a large commercial trailer manufacturer in both Canada and the US.
Old Nov 3, 2013 | 10:11 PM
  #33
shortbedguy's Avatar
I did a test run the trailer did good but the extension were low
Old Nov 19, 2013 | 09:05 PM
  #34
air bagged trailer
here's my first load 500 miles round trip.the suspension is really quiet.
Old Mar 17, 2014 | 09:09 PM
  #35
airbaggedtrailer
I loaded up the trailer and went to a local car show I ended up winning 3rd place trophy
Old Mar 18, 2014 | 01:54 PM
  #36
AirLiftCompany's Avatar
Starter Sponsor
Nice! I've been wanting to make a trip out to Cali for that show.
Old Apr 6, 2014 | 05:36 PM
  #37
went another car show in Visalia ca went through the scales at 15800 pounds
Old May 26, 2014 | 11:50 PM
  #38
I added upper ramps and a lower deck
Old Jun 19, 2014 | 09:29 PM
  #39
a guy needed to have my other trailer.I started building a new trailer it's going to be 34 feet long with two 8 lug axles I'm going to be using 4 Goodyear air springs (2b9-229)
Old Jul 23, 2014 | 09:44 PM
  #40
I'm going to redo the bags only got 8 inches of lift I was looking for 10
Old Aug 2, 2014 | 07:12 PM
  #41
New bags
Old Oct 26, 2014 | 07:49 PM
  #42
here's a video of the trailer
Old Oct 27, 2014 | 11:20 AM
  #43
Busboy's Avatar
Very nice new build, have you thought of enclosing the under storage compartment? It would make it cleaner and secure.
Ian
Jun 26, 2005 05:04 AM
TonyB
May 15, 2005 03:37 PM
tobyw
Sep 25, 2003 12:04 PM
tobyw
Sep 24, 2003 08:49 AM
Big dawg
Nov 30, 2002 10:01 AM
