Towing question fuel milage, auto or 6spd?
I just want to see what everyone else is getting. I am thinking about getting a new truck after the first of the year. I do a lot of pulling with my truck. I haul a 3-4 car hauler and stay loaded all the time. I have had no probs with my 6spd G-56 in my '05.
I have hauled with other guys with autos and they get a little better fuel milage than I do pulling the exact same trailer and load.
I want to know what is the best in fuel milage and in long run as far as repairs a good solid built auto for pulling or the tried and true manual. The only thing I have done to mine is a clutch and all the other goodies at 208K miles. Will I get that kind of life from an auto under heavy pulling conditions? Any input would be greatly appreciated!
I also haul a 3/4 car trailer (Countryside) I have the NV5600 though so the gear ratios are a bit different than yours. Fully loaded I get just under 12MPG I dont have much either only the Volant intake and my cat is MIA otherwise stock. As of today im at 311,994 miles.
Trick is, they changed the final ratio on the 6 speeds for 08, so you will be geared much closer to what those Auto guys are running in OD.
The 05/06/07's usually run about 2000 RPM's at 63-63 MPH, should be more like 1950 with the "new" 6th gear in the G-units.
I would stick with the manual, as you said, you've had no trouble with it!
Fuel mileage
waam here, I get 12 to 13 most of the time, pulling my 10,000 lb fiver. At 65 mph my rpm's are always just below 2000 rpm's but I have a 3.55 rear axel ratio, and I pull in overdrive most of the time. In windy weather and in hill country I don't always get 12 mpg. waam Holland, Mich.
If the final drive ratio is the same, it is possible to get better mileage with the manual. There is less internal resistance in a manual than an auto. You can also anticipate better than an auto. A lot of people with the manuals have a tendancy to lug the engine thinking that they will get better fuel mileage and it actually gives them much worse mileage.
It looks like next year, the new trucks will have very similar final drive ratios so the manual should get better mileage driven properly.
Everyone of my stick trucks averaged better milage then the auto's. I had a 5spd '02 with 3.55's and 35" tires that got 18mpg empty. All of my auto's averaged around 17mpg empty. With 285 tires or smaller the stick trucks would average right around 20-21mpg.
As far as how to drive to avoid lugging, you are correct that 1600rpm at no load is not lugging. The more power that you need from your engine, the more rpm you should run. If you don't need any power, you should be idling(or turn the thing off). The most efficient power versus fuel consumption generally occurs at torque peak or slightly above it so something like 1900rpm for these motors. The most efficient power output for all other throttle settings falls somewhere in between.
Most "efficient" power happens at lowest BSFC. That's 2K rpm for a 24V (VP truck) and 1600rpm for a stock 12v. I have no idea where it is for a HPCR truck, but it's probably right around 2K, maybe a hair higher.
jh
jh
Dually Driver
13
Nov 13, 2007 09:10 PM
Road Traveler
20
Nov 12, 2007 01:30 PM
westport
Nov 24, 2005 01:43 AM
