towing capacity
Old Aug 25, 2009 | 04:09 PM
cooks3743's Avatar
towing capacity
I just purchased a 250 diesel reg. cab. I need some guidence if possible. The manual indicates the GVWR is 9000#. GAWR Front is 4630# and GAWR Rear is 6000# I just weighed the truck with two passengers and tool box. The weight was 7100# Does that leave only 1900# that can be put in the bed. The FW I have has a pin weight oh 2230#. Does that mean I'm over loaded? The Ford I traded in worked fine. I hope the Dodge does too.
Any help is greatly appreciated.
Old Aug 25, 2009 | 04:25 PM
klx650a2's Avatar
Legally, yes, but if you do a search, there is LOTS of info about this subject.
Old Aug 25, 2009 | 06:57 PM
2006Mega's Avatar
make sure that your tires are rated for the weight, your rear axle should be, but you may have load range D tires on, which are not strong enough.
Old Aug 26, 2009 | 11:50 AM
nkennedy's Avatar
What year 2500? I have an 01' 2500, and pull a fifth wheel with a simular pin weight. I do have factory overload springs, a D80 rear, 265 tires, and sway bars though.
Old Aug 26, 2009 | 12:17 PM
cooks3743's Avatar
I have a 2009 Reg cab, 3:73 Diff. I just put the fiver one this morning and the bed only dropped 2.5 inches. It has 4 leaves in the springs. I don't think I'll need overloads. I just had the rear axel weighed at 2800# That leaves 3200# before the axles are overloaded. I think I'll be ok.
Thanks for your response
edonald849
Feb 22, 2009 04:44 PM
CTD_Neil
Feb 19, 2004 09:46 PM
rshelton88
Oct 15, 2003 03:54 PM
Cumminsdude
Aug 14, 2003 07:44 AM
James2
Aug 1, 2003 09:05 AM
