Sway control.
Old Oct 31, 2004 | 05:55 AM
Dodgezilla's Avatar
Sway control.
Can I use sway control without a special reciever? I'm not sure I need the weight distribution hitch but many of the sway control setups I've seen connect to the WDH reciever.
Old Nov 1, 2004 | 12:04 PM
waam's Avatar
Lest we forget
sway control
Get a reciever head with a small ball along side the large the ball. Then you can get the same ball size on a bracket thats clamps on your trailer frame. Some company makes that anti sway controller. It' a two pc. flat stock, where one pc. slides into the other pc. It has a set screw of about 3/8 or 1/2 inch to thighten the friction to help stop sway. RV dealers sell them and I think Reese hitch Co. makes them. Myself I would want the sway bars, but then you have to buy a new reciever for your two inch sq. hole in your truck frame hitch, that will handle sway bars.
waam Holland, Mich.
Old Nov 10, 2004 | 02:59 PM
dodgedude361's Avatar
IMO, a friction sway will not help with that 30 footer. I tow a 30 footer, and i have the reese dual cam setup, I used the friction bar on my old 24 footer.
If you realy want the friction setup, i have one for sale.....slightly used.
Old Nov 10, 2004 | 04:53 PM
Dodgezilla's Avatar
The only problem I have is if I go over 65 mph when the trailer is loaded. If not then I'm fine. I'm just not sure if I need anything at all...... Let me know what you would like to get for the used unit.......
Thanks for the replies
klx650a2
Jan 18, 2009 10:28 AM
Pop-Pop
Jan 21, 2006 12:20 PM
Dodgezilla
Dec 20, 2004 04:24 PM
Dodgezilla
Nov 14, 2004 09:59 PM
javabeanjava
Mar 2, 2004 07:55 AM
