Receiver Height '04 3500 QC SRW?
Old Jan 5, 2004 | 07:21 AM
handymantim's Avatar
Please help.
I have an '04 3500 quadcab SRW on order but want to buy the drawbar for the hitch in advance. If I knew how far it was from the ground to the top of the receiver tube on the hitch I could buy that drawbar now.
Anyone know how far it is from the ground to the top of the receiver tube on an '04 3500 quadcab SRW?
Thanks!
Old Jan 5, 2004 | 11:05 AM
bulabula's Avatar
Re: Receiver Height '04 3500 QC SRW?
Originally posted by handymantim
Please help.
Thanks!
Is it a 4x4? If so, I can measure my 2500 4x4 when I get home to get you close.
Old Jan 5, 2004 | 11:44 AM
Oooops, sorry. No it is not a 4x4.
Thanks!
Old Jan 5, 2004 | 01:12 PM
txtode1's Avatar
Receiver height
Mine is 19" to top of receiver. '04 3500 SRW 2WD
Old Jan 7, 2004 | 08:10 AM
Thanks for the info!
Old Jan 9, 2004 | 10:11 PM
Posm's Avatar
My 04 3500 SRW squats a lot more than my 2500 2000 did. this may affect the "loaded height".
Bryan
Old Jan 11, 2004 | 11:04 AM
SuperGewl's Avatar
Don't waste your time tring to buy the drawbar until you get the truck. The reason is that depending on the load you are carrying you may need more than one drawbar. If you only tow one thing and never change the weight of it and how the weight is distributed then you will be ok with just one draw bar. If yo are towing a TT then you will need a weight distribution hitch setup and you need the trailer attached and loaded the way you plan on traveling with it to help set the hitsh correctly.
Mine is a 4X4 and drops out 4" when pulling the TT I had so I had to have the hitch set at about a neutral so that when hooked up the TT was level and the rear of the truck set correctly.
Old Jan 11, 2004 | 08:46 PM
Those are good points. I'll probably wait to get the truck and see how much it sags with my trailer attached before buying the correct draw bar. I have an enclosed utility trailer with a fairly consistent load so I'd better just wait until the truck arrives (it's scheduled to ship on 12 Jan....I'm just about splitting with anxiety).
From what I've been reading on this site, it's probably a good idea that I drive the truck for about 500 miles under light load to break in the differential anyway.
Thanks for the help!
MikeRP
79
Nov 21, 2016 10:19 PM
LongRanger
Feb 2, 2010 10:03 AM
dragginlx
15
Mar 9, 2007 11:32 AM
mestdagh
May 7, 2005 07:23 PM
alvinator
Apr 3, 2003 05:00 PM
