Prodigy P3 problem
Old Oct 11, 2008 | 07:10 PM
oilfield-trash's Avatar
Prodigy P3 problem
When hooked up to my trailer with electric brakes, P3 flashes "circuit overload - no brakes". But brakes work just fine.
When hooked up to my trailer with elec/hyd brakes the controller flashes "no trailer connected". But the brakes also work just fine. Controller will flash from normal screen to the "no trailer connected" screen.
whats up? any ideas? This just started the other day.
Old Oct 11, 2008 | 10:26 PM
Colo_River_Ram's Avatar
With age comes the cage
You've checked all wiring and set the P3 to the correct brake type?
Old Oct 12, 2008 | 12:05 PM
Cobra909's Avatar
"Controller will flash from normal screen to the "no trailer connected" screen."
Is this continuous and short time span or several minutes between?
Sure sounds like maybe a loose connection on your truck.
Old Oct 12, 2008 | 01:04 PM
rich's Avatar
check the pins on your truck plug they may need to spread out some . mine sometimes get squished together and dont make proper contact
Old Oct 14, 2008 | 08:27 AM
snowball's Avatar
Check your ground between truck and junction box on the trailer
Old Oct 14, 2008 | 10:51 PM
Cobra909's Avatar
How 'bout it Oilfield-Trash...any luck?
Old Oct 15, 2008 | 05:45 PM
Ran a diagnostic on it and its worked ever since. I am going to this weekend crawl up under the truck and check all the wire. Been thru some pretty nasty stuff here lately.
thanks for the help
stickk
Aug 5, 2010 12:07 AM
Sevir
Jun 29, 2007 01:08 PM
Krazytoy
Nov 9, 2006 01:36 AM
CTD23
Jun 9, 2006 09:32 PM
Synchiropus
Oct 8, 2003 11:33 PM
