Prodigy Brake Controller Settings???
Old Aug 28, 2007 | 07:00 PM
ccoop769's Avatar
My vehicle weighs in at 7400 pounds with full tank of fuel!!!!!
My avg load is 20,000 pounds!!!!!
What do you guys like for the gain???
How about boost???
Please respond with your GAIN-BOOST-YOURLOAD
I leave mine at 3.0 with no boost but im thinking I should raise em more!!!!
Old Aug 28, 2007 | 09:07 PM
surfram's Avatar
Prodigy recommends that you start at 6.0 and increase braking until the trailer will lock up during a 20mph panic stop. Then back off slightly on the controller. I run boost 2 or 3 in dry higher speed driving and no boost in the rain with the max set at between 8.0 and 9.0 with an approx. 6,500lb trailer.
Old Aug 29, 2007 | 06:18 AM
TreeFarm's Avatar
3,000# gross single axle trailer fully loaded:
Dialed to 6, boost 1
10,000# gross dual axle trailer at 7,500#:
Dialed to 12, boost 3 on pavement, boost 0 on gravel
Old Aug 30, 2007 | 08:46 AM
ccoop769's Avatar
haha, so really i just need to max out my settings and boost when its dry outside then!!!!!! fully loaded of coarse..
Old Aug 30, 2007 | 08:55 AM
92DuallyCTD's Avatar
^^Same here^^
Old Aug 30, 2007 | 09:03 AM
TreeFarm's Avatar
Boost 1 or higher does more than boosting the degree of brake application. It lightly applies the trailer brakes as soon as the brake light comes on, thus eliminating the small lag in trailer braking that occurs when you rely on the controller detected inertia change alone.
The only reason I turn off boost on gravel or dirt is my equipment trailer brakes lock on loose surfaces if I don't. This particular trailer, a Kaufman, has brand X brakes, in other words, not Dexters, and I wish to hell I had never bought it.
kayjh
Jun 27, 2006 12:11 PM
tdupuis
Oct 1, 2004 10:49 PM
Synchiropus
Oct 8, 2003 11:33 PM
hotdram
Jun 25, 2003 08:36 PM
Buzz
Jan 24, 2003 11:21 AM
