prodigy brake controller help!
Old Jan 21, 2007 | 10:45 AM
DCinTX's Avatar
Im installing a prodigy brake controller and am on the final step, connecting the red wire from controller to my trucks brake pedal switch, but the switch has five wires to it, so......which wire do i splice into?2001 2500
Thanks in advance, Chris
Old Jan 21, 2007 | 11:59 AM
infidel's Avatar
Sorry don't know the colors.
Two wires are for the cruise and auto tranny, the other two to the brake lights. Not sure on the fifth wire, a ground perhaps? You want the outgoing wire for the lights. Not sure on a 2001 but think it's a negative path.
Old Jan 21, 2007 | 06:19 PM
cLAYH's Avatar
On my 2001 there was a connector under the dash for all 4 wires. When I ordered my Prodigy I asked for the pigtail for my truck. This let me plug the Prodigy directly into the wiring harness. However if you didn't get it you can order one from the dealer($30CDN) or just use some falt blade connectors to plug into the receptacle under the dash. My receptacle was on the left side. You shouldn't need to splice into the factory harness if its an '01
Old Jan 25, 2007 | 01:15 AM
camelracer's Avatar
My '02 manual says it's the white/tan wire out of the brake switch.
Old Jan 25, 2007 | 11:23 AM
01RAMer's Avatar
I'm guessing his didn't come with a tow package or he'd have the connector we have, located above the E brake. If he has a factory hitch I bet he has the connector.
Old Jan 25, 2007 | 02:56 PM
Moose10's Avatar
Yep mine was the same as yours cLAYH. Easy hookup, and I screwed the mounting bracket into the ashtray door.
DCinTX, does your truck have the factory trailer hitch?
kayjh
Jun 27, 2006 12:11 PM
tdupuis
Oct 1, 2004 10:49 PM
Synchiropus
Oct 8, 2003 11:33 PM
hotdram
Jun 25, 2003 08:36 PM
Buzz
Jan 24, 2003 11:21 AM
