Pin Weights
It's more about balance than pin weight. You need to load your cargo so that you maintain good control and traction over changing road and environmental conditions.
without enough tongue weight a BP will fishtail and give you a much bumpier ride. Is 15% the right amount? What about gooseneck?
Pin weight on goosenecks may depend on the distance between your rear truck drive axle and the forward trailer axle (known as the "bridge"). My 25' deck over transfers 25% (19 rear 6 to front). However, my 44' enclosed trailer (10 foot longer bridge) transfers 33% to the truck. Position of load may have some effect on pin weight. Do as billmrmi suggested - empty weight of truck on scale (full fuel, and you) -look at your axle weights. Add empty trailer - now look at them - you'll not only see total transfer but also transfer distribution.
Cowboy_Customs
Oct 18, 2011 01:46 AM
