overheating while backing
Old Jul 8, 2009 | 12:42 AM
  #31
gadget.35-06's Avatar
Originally Posted by torquefan
I've seen a few trucks where someone has installed a trailer hitch on the front. I imagine they do that so they can back up their trailer without making the engine turn backwards.
Yeah, but the front might fall off. Like that oil tanker near Australia a few years ago.
Old Jul 8, 2009 | 06:51 AM
  #32
blackimpala's Avatar
I have been investigating a 2 wheel low system just for backing the TT. I'm still looking.
Floyd
Old Jul 8, 2009 | 07:52 AM
  #33
RowJ's Avatar
There is one. 'BNold' (above) has one. He installed 2-3 for other DTR TX #8 members 2 yrs ago.
Believe it involves an inexpensive Nissan relay switch of some kind.
Try pm'ing him (or a search). He was married last weekend, so may be a while before he gets back to you!
RJ
Old Jul 8, 2009 | 08:56 AM
  #34
bigfoot's Avatar
Urban Legend
It may come as a surprise to some but the old Detroit 238 would run backward. Sounded like a trashing machine but is would run.
Old Jul 10, 2009 | 09:51 AM
  #35
1-2-3's Avatar
Just a plain ole guy
Originally Posted by HOHN
Herb, the engine is overheating when you back up because the fan is trying to push air out the front of the truck.
Since the engine is turning the opposite direction, I'd also assume that the coolant flow is not optimized, allowing the heads to get too hot.
Maybe they can come up with a way to keep the engine spinning the same direction all the time someday?
I found a way to over come this. Real simple. You just flip the truck over when backing. You might want to add cab lights to keep your paint from getting scratched.
Old Jul 10, 2009 | 10:07 PM
  #36
WestTN's Avatar
It is likely the fan hub is failing. It should engage fully when the water temp is approximately 206 degrees. Another possibility is the dirty radiator caused by the crankcase vent bottle. When pushing a heavy RV backwards with an automatic transmission there would be a lot of heat generated and no way to get rid of it.
DPG
Jul 6, 2010 11:45 AM
Flyfishy
Jan 9, 2008 11:00 AM
95black2615
Jul 22, 2006 02:19 PM
052500#1
Jan 11, 2005 04:09 PM
PADZZ
May 24, 2004 08:02 PM
