Largest tire -stock suspencion??
02 dodge 2500 no lift what is the largest tire say pro comp -that will fit?? 285's is what i'm being told is that true?? thanks in advance--yes i tried a search--Glenn
nope
its not true, 305s and larger will rub, HOWEVER 295's are taller and not as wide as 305s, those are the best fit... I have 285s but will go 295s next time around, mind u im lifted tho..
Tx
Tx
315's rub on the stock control arms and the plastic inner fender if you compress the suspension at all. if you put aftermarket wheels with different backspacing on it, then it will rub on the fenderwells bad. if you lift it, it will still rub on the control arms but it won't rub anywhere else.
eldorado
08-21-2005 07:51 PM
Original Junior
06-14-2005 09:40 PM
