brake fuse
Old Mar 11, 2003 | 08:43 PM
jerryb's Avatar
brake fuse
Where is the fuse for my trailer brake control?<br>I have lost all power to the harness under the dash. All the lights for the truck are fine but no power for the trailer. I looked at the fuse block in the dash and under the hood but did not find one labled for trailer or anything I thought would be likely.<br>Thanks, jerryb
Old Mar 11, 2003 | 08:48 PM
FiverBob's Avatar
Re:brake fuse
Jerry,<br><br>What year truck? If it is a 2003 with trailer haul option, there is a 40amp under the hood in the fuse block.
Old Mar 12, 2003 | 04:21 AM
Casey Balvert's Avatar
Re:brake fuse
I believe all the Gen 2 trucks had them under the hood in the Power Distribution Center as well. My 97 did.<br><br>Casey
Old Mar 12, 2003 | 09:21 AM
jerryb's Avatar
Re:brake fuse
Sorry about that it's a 2001 Dodge, there are no fuses labled for trailer power or anything likely. The fuses are numbered, anyone know what number fuse powers the trailer harness.
Old Mar 12, 2003 | 06:08 PM
FiverBob's Avatar
Re:brake fuse
Jerry,<br><br>If no 2001'ers answer you, I would suggest looking at your box, pull all 40 amp fuses and test them with an ohm meter. I would assume it is a 40 amp - - my V10 2000 had a 40. Did you look on the bottom side of the lid of the fuse panel? I can't remember if mine was labeled or not - - the 03's are labeled.
Old Mar 12, 2003 | 06:21 PM
erics76's Avatar
Re:brake fuse
I've got an '02, it's listed as #9. It's a 40 amp, as you're looking at the fuse block from the drivers side of the truck, go to the top left hand. There are 2 rows of 6 of those rectangle shaped fuses. The one listed as &quot;trailer&quot; on mine is in the second row, 2nd one down from the top. Hope that helps
Old Mar 13, 2003 | 09:22 AM
Big dawg's Avatar
Re:brake fuse
I did the same thing last time I towed. It's under the hood, a 40 amp, I thought mine was labled &quot;trailer&quot; It's the 3rd or 4th fuse on the right side (facing the cummings). Hope this helps...<br>Big dawg
Old Mar 13, 2003 | 10:04 AM
shortfieldbreak's Avatar
Re:brake fuse
I have a 2001 and the fuse is under the hood, labeled #8. It's a 40 amp. <br><br>-SFB
Old Mar 13, 2003 | 07:54 PM
jerryb's Avatar
Re:brake fuse
I must have had a bad day, I looked again this morning and it was right there, labeled and everything, I threw those glass's away. I think what blew the fuse was using a Chev 7 wire to 4 wire adapter last week when I was in a hurry.<br>Thanks for the help, jerryb
bigjohn92
Nov 25, 2010 01:32 PM
eng208
Mar 28, 2006 06:25 PM
Evildiesel
Nov 18, 2005 04:12 PM
DEC
Nov 6, 2003 06:48 PM
