Brake controller
Old Dec 18, 2005 | 04:02 PM
spro2395's Avatar
Brake controller
Where did you mount your brake controller? Iam leaning toward the prodigy. I had one in my last truck and I thought it worked well but I cant decide where to put it in the 05.Thanks Joe Z
Old Dec 18, 2005 | 04:17 PM
bbhzx12's Avatar
Mine's just to the right of the Ebrake pedal, don't like it too much but I don't hit it and I couldn't find anyplace better.
Old Dec 18, 2005 | 04:38 PM
FiverBob's Avatar
Just a suggestion - - lean the other way and look at a Jordan Ultima. You will love it a lot more than a Prodigy. Much smoother controller. Those of us who have used both much prefer the Jordan.
Welcome to the site.
Old Dec 19, 2005 | 06:29 AM
SuperGewl's Avatar
Check my web site for pics of the locations.
Old Dec 19, 2005 | 06:51 AM
wap's Avatar
wap
I am puttin a jordan in mine tonight and still havent figured out where I am goin to mount it.
Old Dec 25, 2005 | 11:28 PM
xdevildog's Avatar
Brake Controller Connections
How does the jordan brake controller tie in to the wireing? is there an adapter to just plug in or do you have to get the right unit?
I will be installing this on an 04 shortbox 4x4 laramie quadcab 2500 auto.
any sugestions or comments from those in the know will be greatly appreciated.
mike
Old Dec 26, 2005 | 08:07 AM
Patrick Campbell's Avatar
The jordan mounts goes to the power, ground, and brake wire (blue) but does not use the brake pedal sense wire. Instead it uses a cable that actually actuates the brakes in proportion with how you go on the brake pedal.
Old Dec 26, 2005 | 02:15 PM
FiverBob's Avatar
mike
Mike, we are all assuming you have the factory plug for the truck - - are we correct??? If not, see your friendly Dodge dealer. You will wire that up to the controller following the directions and plug the result into the socket under the dash. Let us know if you need help.
Bob
Old Dec 26, 2005 | 02:23 PM
Scotty's Avatar
Top's Younger Twin
https://www.dieseltruckresource.com/...cat=500&page=1
Old Dec 26, 2005 | 03:46 PM
FAY's Avatar
FAY
Brake Controller Location
I had a difficult time deciding where to put a brake controller in my 05 Dodge truck. Actually, I have a difficult time finding a space to put any type of accessory in these new units. I positioned the controller unit on its side and screwed its mounting bracket to the driver's side of the plastic centre console that is situated in front of the manual tranny gear shift lever. The controller unit sits low, but far enough away from the fuel feed petal that my right foot never strikes it. In my GMC gas job I attached the controller on the left side of the steering column under the edge of the dash. The new Dodge dash is different to work with, but it came with a good long controller adapter wiring harness and plug. The adaptor plug's mate in my truck wiring harness was tucked so far way back and up under the dash that it was somewhat difficult to find on the left side. I need my right hand free to shift gears; therefore, I can also ajust the controller with my free right hand for different trailers.
Old Dec 27, 2005 | 07:43 PM
xdevildog's Avatar
brake controller
can someone e-mail me with a good place to pick up or order the jordan ultima controller?
Old Dec 27, 2005 | 08:57 PM
www.bestbrakecontroller.com
Busboy
21
Jun 10, 2011 11:39 AM
kingofdodge7131
Jan 31, 2010 10:15 AM
DuaneWKKC
May 9, 2003 11:08 PM
atc250r
Mar 22, 2003 12:27 PM
PADZZ
Mar 18, 2003 09:47 AM
