another diesel fuel thread...
I wonder if the moderators panicked. LOLI am wondering if anyone RVing has tried a diesel fired furnace or oven like in the marine applications?
Also, after searching with Google I was unable to come up with a response for something else...a diesel catalytic stove top. I saw one on Earthroamer that was a glass top...nice unit. Did not get a reply from there.
I think it would make a lot of sense especially if one could use homebrew Bio and delete the propane. Run the fridge on 12 or 110 volt.
Scotty
Those Earthroamers are pretty nice. Though built on a Ford, I think you can specify an F650 (and get a Cummins).
Anyhow, I believe they also run a diesel powered furnace, and electric powered fridge...
Seems to me, though, that the furnace must have a fuel pump that would presumably draw a bunch more power than a propane furnace.
It is the fan that pulls the current on the forced air furnaces. I used to have a sailboat with a deisel heater, it had a small automotive fuel pump that had a minor current draw. The heater was a wall mount with no fan. It did a thermal circulate thing with no fan. It worked great. You could run it for days with 12V.
I guess propane is safer but you still have to drag two fuels.
I was thinking that with the rising costs of fuel [propane included] running veggy homebrew oil would be the way to go. The safety aspect on a marine application might be different then an RV but they sure prefer the diesel heat over the propane. Maybe cuz they are diesel boats?
If I use homebrew fuel to do the heating and cooking, at least it would smell better then diesel fuel too. LOL
With the correct solar panels and batteries, one could run a long time dry camping with this set up.
There are some real efficient fridges out there not too. 12/110 volt.
I wonder if there is a way to run AC off the veggy fuel too? Without a generator?
Scotty
Scotty
Good for heating and cooking,,,,,,,
I had a Beaver motorhome, 425 HP CAT, Diesel generator, and it utilized diesel for both the water heater & heating the coach. It was very economical and got its fuel from the 110-gallon main diesel tank.
They are probably illegal, banned or need to be registered and put in a common safe up here.
LOL
I found the oven/heater/stove and it will fit right in the normal spot for a standard RV stove.
It also has an option for the water heater.
Scotty
LOL
Scotty
Tommy93w350
15
Sep 25, 2012 07:51 PM
schoust
Oct 21, 2009 10:09 AM
JohnnyH
16
Sep 26, 2007 10:34 PM
Jezzhuntin
Aug 25, 2006 02:51 PM
