Adjusting trailer brakes
Old Apr 9, 2003 | 07:08 PM
Stevie G's Avatar
Okay gang, how does one go about adjusting electric trailer brakes? Searched the archives with no results.<br>Is there a clearance measurement you are shooting for?<br>My brakes have a definite pull when applied but will not stop the trailer. I figure I need a way to get all six wheels adjusted for the same stopping power. Is this a correct assumption (That word again)?
Old Apr 9, 2003 | 08:09 PM
gofastman's Avatar
Re:Adjusting trailer brakes
Let me ask first off, when you say pull, do you mean that you can feel the trailer pull to one side when you aply your brakes.<br>Second, When you say that it doesnt stop, are you wanting the trailer brakes to stopped itself plus the truck ?<br>When you say that it has six wheels, that tells me that it must be a 37ft or bigger, and that it is a heavy one at that.<br>Please give me more info so as i can help you with your problem.
Old Apr 9, 2003 | 11:53 PM
Haulin_in_Dixie's Avatar
Adjusting brakes is adjusting brakes, regardless of what it is on. Jack up the wheel, adjust the star wheel (adjuster) untill there is heavy drag on the wheel when trying to turn it and then back off the adjuster until the wheel turns free. Do that to all the wheels and then try it. If there is pull or other problems start pulling wheels to find out why, they are adjusted right.
Old Apr 10, 2003 | 12:04 AM
tool's Avatar
If your brakes are badly out of adjustment, get someone to apply the actuator while you try to turn the drum a little to center the shoes to make sure you get proper adjustment. Other wise you may turn the starwheel and one shoe will move out until it contacts the drum and the other may hang up, not moving. You might think you have proper adjustment but after using the brakes a couple times the shoes center in the drum again and will not be adjusted properly.<br><br>If it is really pulling to one side badly you may have one or more brakes that aren't working.<br><br>ie. 2 brakes work on one side of the trailer, 3 on the other.
Old Apr 10, 2003 | 03:13 AM
Oh yeah and the fast way to check them to see if they are operational is to use a cheap compass. Have someone hold the controller on and walk around running the compass past each wheel, it should follow the wheel, if not the brake is not working on that wheel.
Old Apr 10, 2003 | 09:55 AM
Stevie G's Avatar
Thanks gang!<br>&quot;Pull&quot; meaning they are working, just not enough.<br>Haulin, thanks for the procedure. That's how I've always done brakes. I've just never had six of them that were supposed to work together.<br>Yes, it is a &quot;Big one&quot;. Follow the link in my signature.<br>http://www.swampfoxcustoms.com/hot_shot.htm<br>This forum is great!!<br>Keep up the good work/support.<br>
Old Apr 10, 2003 | 06:27 PM
FiverBob's Avatar
[quote author=Haulin in Dixie link=board=11;threadid=13412;start=0#126360 date=1049962437]
[/quote]
AND, if you are using a Jordan controller, you can monitor the current being drawn by the braking circuit to determine that all the magnets are at least pulling current. 2 1/2 - 3 amps per wheel, times 6 wheels means it should read between 15 and 18 amps. Pretty neat.
Old Apr 10, 2003 | 07:11 PM
Jim O's Avatar
When ever mine pulls one way it is usually a broken wire and I also use a compass to find it. the slush an snow usually adds a couple of pounds pull on the wire and it breaks. My magnets are 5 amps at full power my brakes are 12&quot; by 3&quot; drums with 8 stud wheels. I must say that Jordan brake controler sounds like the way to go. I will sure look into it if my prodigy ever fails.<br>Jim O
Old Apr 10, 2003 | 08:20 PM
I never purchase the shoes or magnets seperately. I purchase the whole assembly cheaper and five bolts puts it on then all is new. I always have extra stuff around if a magnet should go out along the way. Also I have never been a lover of the wet bearings. I have over 100,000 on the current grease packed bearings and have not lost one yet. I do repack whenever I pull a wheel off the trailer. I carry an extra set of bearings just in case.... along with an extra U joint, fuel filter, jordan controller, rear truck axle seals and bearings, and a bunch of tools to handle it on the road. Just good insurance.
Old Apr 10, 2003 | 09:03 PM
If you change to the Jordan now you will not be sorry, it is that much better. Sure does save the truck brakes.
Old Apr 11, 2003 | 07:49 AM
Stevie G's Avatar
Who has the best deal on Jordan controllers and what makes them so special?<br>The Amp draw of the brakes would be nice.<br>The one I'm running now is tied into the hydraulic brakes on the truck and has a separate bias controler. I guess I'll have to look for a name on it somewhere.
Aug 19, 2011 09:17 PM
killed300ex
Jan 14, 2008 07:59 PM
95ram
Jun 25, 2007 01:46 PM
Timberman
Jun 20, 2006 06:20 PM
wildcargo
Nov 29, 2005 04:20 AM
