Actual Towing Limits
I have question about Towing.
How much can I really tow?
2006, 5.9, auto 4x4 Mega.
Spec says I can tow 12450
GVWR 9000
GCWR 20000
So based on a GCWR of 20000, I should only tow a trailer that has a GCWR of 11000.
20000 - 9000 = 11000.
Right?
Also, this is a bumper pull, so the hitch weight should not exceed 1200.
Right.
Thanks,
Stealth
GVWR 9000
GCWR 20000
Right?
Right.
Thanks,
Stealth
"Also, this is a bumper pull, so the hitch weight should not exceed 1200."
If you don't have a WD hitch, I believe w/factory hitch about 500 tongue(hitch) weight is as much as you want to go. You can get a WD hitch that is rated for #1K TW, #10K trailer weight. It would be one heck of a ride w/#1,200 tongue weight & no WD hitch!
My .02
My .02
[QUOTE=Stealth06Ram;1906726]I have question about Towing.
GVWR 9000
GCWR 20000
Right?
Right.
Common sense has to play a part in your decision. I'd say sure you can tow it, but you better have excellent trailer brakes, a good controller and not go through the mountains in the winter or be speeding along in traffic a 80 MPH, etc. I wouldn't do it all the time, but maybe for a short distance in good weather. Why would you want to tow that load on a regular basis? If you do maybe a bigger truck makes sense. What are you planning to do?
John
GVWR 9000
GCWR 20000
Right?
Right.
John
John
Thanks for the responses, I guess I should have stated this from a LEGAL perspective.
Legally, you should not exceed the GCWR of 20K, So if the Truck has a GVWR of 9K, the trailer should only be rated for a GVWR of 11K. From a Legal Perspective.
Stealth
Comments?
Stealth
Comments?
From: Used to be missoula, montana: Now in Sonoma County California
manufacturers GCVWR is a recommendation.
legal GCVW is determined by adding the licensed GVW of the truck with the licensed trailer GVW. So long as you are not exceeding the tire load ratings at any one axle you will be legal. there is more that goes into it but that is the basics
I know when you read the laws of various states on towing multiple trailers, it specifically states you cannot go past the tow vehicles GCWR. Doesn't say, "we recommend you don't exceed the GCWR". When I moved to CO, I read the laws for WI, MN, IO, NE, and CO. I would doubt it is any different when towing just one trailer. If I'm understanding the way ddestruel's example, I can hook a semi trailer behind my dodge if I can get it coupled and be legal.
The laws should read "Do not exceed the licensed GCWR of the tow vehicle" otherwise half the RVrs and all the Hotshots out there would be in jail.
So far, your quote appears to be correct. I'm looking in the WI laws because I'm more familier with that state and they have an awesome online utility for navigating the state statutes. Also, WI will allow you to underlicense the weight capacity of a truck. I can put a half-ton plate on a 3/4 ton truck and pay a lower fee. There has to be a statute here that says you cannot license the vehicle greater than the manufacturer's rating.
I did not look in here for your truck, but here is a link to Dodge towing guide.
http://www-5.dodge.com/towing5/D/home.html
Right?
Right?
If you want to stay within ratings, I'd say...
20000 (mfg's gross combined rating) minus what the truck scales at with passengers and ready to tow = what the trailer can weigh without exceeding the truck's combined rating...
