4WD low or not?
Old Jan 7, 2007 | 09:07 AM
mikelobaugh's Avatar
4WD low or not?
I tow a 38' toyhauler behind my '06 2500 short bed 4x4. I live in it for my work in the oilfields of the Tx. panhandle. The rig roads are usually rough, wind and snake around and up and down thru gullies and hills. When I come upon the steeper inclines, should I put the truck in 4WD low? When I have done this before, the truck seems to have an easier time pulling up the hill, but I don't know what effect this has on my tranny. I have been shifting back to 2WD as soon as I get to level ground. Most of the rig roads are less than 5 miles off of the pavement to get to location
Old Jan 7, 2007 | 09:42 AM
adkl1's Avatar
Well first of all you are over your trucks GCRW with that set up not that you were asking that ?. But to the ? in hand is as long as you dont keep it in 4low for very long and dont make a turn with it i think you wouldn't do any damage.
Old Jan 7, 2007 | 11:54 AM
XLR8R's Avatar
Unless you're on concrete or asphalt, you should be able to drive in 4-LO indefinitely.
Old Jan 7, 2007 | 04:47 PM
06inferno's Avatar
youll be fine in 4low.. i have to use low w/ my gooseneck quite frequently myself and have 36k miles and no problems
Old Jan 7, 2007 | 06:34 PM
dieselengineer's Avatar
Install free spin type hubs and you can use 4 low anywhere and anytime
Old Jan 7, 2007 | 06:39 PM
DodgeCowboy's Avatar
DTR's Cow Boss
I use 4lo alot even sometimes backing a trailer on asphalt only if i keep it strait and need to go slow to worm it into a tight spot. On dirt 4lo is nice because you can back a trailer darn near any were you want and dont have to ride the clutch.
Old Jan 7, 2007 | 09:31 PM
TxDiesel007's Avatar
Posi lock ur rig
and use the 2low feature... Gosh its sweet! I love it!
Rick
Old Jan 7, 2007 | 11:01 PM
BlueDually's Avatar
If its an auto, I would
GCWR of a 2500 is can be 20 000lbs, I wouldnt worry about it.
wcbcruzer
Sep 5, 2008 08:36 AM
wrangler04
Jul 17, 2007 11:00 PM
VikingDiesel
Competition / Pulls / OffRoad
Dec 29, 2006 07:17 PM
95black2615
Dec 20, 2006 06:37 PM
1320
May 6, 2003 06:30 PM
