2ng gen purchase ? 12v vs 24v
Old Jan 4, 2012 | 04:41 PM
wild4stangs's Avatar
OK... Thanks for that info, I will do some reading on this... On average, what does it cost to have a shop replace a VP44?
Old Jan 4, 2012 | 06:25 PM
John_P's Avatar
The remanufactured VP-44 pumps range from $1,015.00 to as high as $1,200.00 depending on where you buy them. They are usually guaranteed by the dealers for about a year as long as the owner does not modify them.
Old Jan 4, 2012 | 06:26 PM
Blake Clark's Avatar
John, just curious, how many miles did you have on that junk 24valve truck of yours?
Old Jan 4, 2012 | 06:28 PM
John_P's Avatar
Wow, that's not good... So I assume it's just a crap shoot on these pumps, no real way to extend the life of the pump ?
You will have members here that have the VP-44 pumps on their trucks that have had good service out of them, but there are just as many that have had them fail. If you go to the "24 Valve Engine and Drivetrain" Section here you can read through the threads and see all the posts about them. IMHO, I will never own another 1998-5-2002 Dodge CTD 24 valve with the VP-44!
Old Jan 4, 2012 | 06:32 PM
John_P's Avatar
Blake, when I sold it, it had 94,000 miles on it. I used the money from that sale to buy the new 2006 Dodge CTD CR that I still have today. That truck now has 123,000 miles on it with no fuel related problems so far. And I have NEVER had ANY fuel issues with my 1996 and that truck has 313,000 miles on it. The P-7100 fuel pumps are TOUGH and RELIABLE!
Old Jan 4, 2012 | 06:40 PM
Oh I know it for sure. One of my favorite trucks ever was my uncles 97 2500 Dually conversion. It lasted him 200k, which in normal people use, is close to oh, about 2 million miles.
Dads 02 is working on 200k. Other than a recirculation door a/c issue, its been perfect.
Old Jan 4, 2012 | 06:50 PM
John_P's Avatar
You Dad is one of those lucky ones with that 2002 Blake.
Old Jan 4, 2012 | 06:55 PM
Seems so. Funny thing is he babied my '90 when it was his. The 02 he ran hard. Wasnt abusive to it, but worked it hard. Never missed a beat.
Old Jan 4, 2012 | 07:10 PM
C Schomer's Avatar
I bought a new 97 3/4t 5 spd 3.54 and had it for 9 yrs. It was the best vehicle I ever owned and so simple to fix anything on it. The 5 spds have more hp than the autos and can take a lot of mods and still be VERY reliable. I fixed the dowel pin, did the mainshaft/5th gear fix, con o clutch, bigger rear wheel cylinders, gutted the cat and had it up to 292hp/812tq. I sold it with 94k and it was without a doubt, better than new. All the week points were fixed and it had the power to get up thru the gears on steep grades with the wide, 5 spd gears and got 21 mpg. I needed a QC badly and I got a bigger 5er which made the 3.54 too high for the slow going roads around here. I moved a 12k lb 5er to a soft dirt storage yard for a friend once and it was murder on the clutch. I'd want the 4.10 for heavy hauling and a dually. If there would have been a 12V quadcab, I would have had one and put a 4.10 in it. I think my early CR is the next best thing but I'd MUCH rather have the all-mechanical fuel system. Craig
Old Jan 5, 2012 | 03:11 PM
1STGENFARMBOY's Avatar
12V is my opinion, i have had 4 cummins trucks 1 with a 24v, never had any problems and worked pretty hard, sold it to my cousin (again because i had never had any problems) and from then on it was nothing but a money pit, vp44, trans, 2 lift pumps,
the more electronics the more potential for problems. my .02
Dar
Old Jan 5, 2012 | 04:47 PM
OK guys I am going to take a look at a 1999 that has the manual and 3:55 gears. Looks like my 15k trailer will exceed the tow rating on the truck by a few hundred pounds. Should I me looking for a 3500 dually instead ?
Old Jan 5, 2012 | 04:51 PM
John_P's Avatar
If you are looking at a 1999 then you will have a VP-44 fuel pump on that truck! If you buy that truck, all I have to say is "Good luck to you!"
Also, if you are towing a 15K trailer IMHO you would be better off with a 3500dually as you pinted out.
Old Jan 5, 2012 | 04:57 PM
Dar
Boy it a good thing that the 4th gens have no electronics that control anything, anywhere.
Whew......
Old Jan 5, 2012 | 05:22 PM
John_P's Avatar
Whew......
Yeah,....RIGHT BLAKE!!
Old Jan 5, 2012 | 06:55 PM
C Schomer's Avatar
Dually... absolutely! My 03 dually is rated 15k, towing. I think an srw would be over, more like 1000s. FWIW, I went to a seminar at a Bosch fuel shop in about 2000 and they said they hadn't seen any failures of vp44s or lift pumps in trucks that used additives (for lubricity) at that time. I have friends with vp44s that haven't had problems with well over 100k miles. From what I've read... it's VERY important to replace the LP at the first sign of low pressure and DON'T run out of fuel. Starving or even worse, air, does irreversible damage. Craig
