Ton of questions
#46
Do not forget the engine also needs a fuel return to the tank.
Jim
#50
Correct, just the factory lift pump is fine.
#52
So after I reinstalled everything the engine doesn't want to turn over off the fuel pump bolt anymore. It spun fine when I had the injectors out as well.think it's just compression?
#53
I usually spin them over using a socket on the harmonic balancer. if they turn over easily
Or I put two bolts into the rear of the crank and use a pry bar wedged between them...Or I install the adapter plate, flex plate or flywheel and then use a barring tool.
#54
Don't use the nut on the IP to turn the motor.....that is not a very big thread on that tapered shaft and you could end up snapping it off! As Oliver suggested the crank bolts are a better choice....that is what I use.
#56
The crank bolts hold all the power the motor makes as it send it to the flex plate or flywheel...
If you want to be really safe use the barring tool as I described earlier.
#60
Alright. Please ignore the gold.. im not here for help with that.. i know it's tacky but i dig it.
Got some pics for some identification..
1- is that my PS pump with no vacuum pump on it? i can't find a nipple for the vacuum.
2- any idea whats up with that alternator? It came off of a grumman with 2 batteries so maybe it's heavy duty.
3- my tensioner is next to the alternator.. i see most engines with it below the alternator. Any idea whats up with that ****?
4 - my huge starter.. are there any smaller starters out there? it's gigantic. i can make it work but im having clearance issues.. Small things.
