Steering Problem
Old May 11, 2018 | 07:39 PM
B Miller's Avatar
Steering Problem
I had a leaking power steering unit, so I changed it with one that was working on another truck that I took apart.
When the front end was up in the air I filled the power steering pump and turned the steering wheel all the way to the right and left,but the fluid level did not go down.
Lowered the truck and found I could not turn the steering wheel either to the right or left.
Could the pump be air bound?
Old May 11, 2018 | 08:52 PM
One cycle, left and right? Jack it back up, and try again. The engine needs to be revved up to 1200 rpm or so, while cycling the steering wheel.
Do not let the ps fluid run dry while doing this. A partner filling it up works best
Old May 12, 2018 | 12:32 AM
Have to disagree with T-man on this one.....From my hydroboost thread....
So a little info about priming the system after a PS pump, PS box or hydroboost change. Over the last couple days I have been doing some reading and research about priming the PS system properly. I'm pretty sure I am the reason the PS pump failed.
Here's What I did,
- fill the reservoir, then remove the power to the FSS and crank the motor for about 10-15 sec, then check the fluid again.
- Then I fired it up for about 10-15 seconds, shut it off and check fluid again.
- Then fired it up again and this time turned lock to lock with wheels off the ground. Took quite a while to finally get hyd pressure through the system.
It was during this air lock situation that I think the pump burned up the seals.
Now after my research I came across a few references to this procedure.
-fill the reservoir with fresh fluid. DO NOT START THE MOTOR! Then with wheels off the ground "slowly" crank the wheels lock to lock (LH and RH). Then check fluid level.
-Continue lock to lock slowly, checking the fluid after each cycle. I did this 10 times (LH to RH and back).
-Then I unhooked the FSS and cranked the motor for about 10-15 sec. Checked the fluid level.
-Did another 5 lock to lock cycles, checking fluid level.
-Crank motor again (FSS unhooked) for another 10-15 sec.
-Then another 5 lock to lock cycles.
-Fired motor up and cranked lock to lock 5 times, checking fluid.
-Dropped wheels back on the ground and everything was smooth as silk.
Old May 12, 2018 | 03:54 AM
B Miller's Avatar
What does Fss stand for?
Old May 12, 2018 | 05:26 AM
Angry Johnny's Avatar
Fuel shutoff solenoid.
Old May 12, 2018 | 05:30 AM
nonrev's Avatar
Super Moderator
10 Year Member
That would be the fuel shut off solenoid on the ve pump, It will keep the engine from starting while you turn it over.
Old May 12, 2018 | 07:22 AM
B Miller's Avatar
Thanks.
Old May 12, 2018 | 07:31 AM
There are different ways to accomplish the same thing. I don't have hydroboost. My description was with 2 people doing the job, one.person filling keeping the,fluid level from dropping in the reservoir , while the other person starts and stops the truck, rotating lock to lock.
I found myself (while doing the process by myself, stopping, and starting like you have, written), intermittently roatating the wheel left to right, and still had no pressure until I revved the engine to 1200 rpm, then shutting it down. It finally had pressure.
I can easily see how you can easily burn up a pump if the fluid level drops too low, hence the reason for having a partner
Old May 12, 2018 | 06:27 PM
B Miller's Avatar
I got it going.
LanceK
Jul 14, 2006 08:08 PM
ocsurf16
Mar 13, 2006 09:24 PM
unioncreek
Jun 29, 2005 02:00 PM
OHFarmboy
Feb 25, 2005 11:30 AM
Jun 5, 2003 09:27 PM
