Your Boost Numbers! Lets See Em
Old Apr 27, 2006 | 11:31 AM
casper_cobra's Avatar
how much boost are you runnin with what mods and turbo with housing sizes
mods in sig, hit 60+ before with an HX35/12
Old Apr 27, 2006 | 11:36 AM
Lil Dog's Avatar
Stickin with the wastegate at 36 psi. Short bursts to the 37-38 if you hit it hard and overrun the wastegate. Stock HX35.
Old Apr 27, 2006 | 11:55 AM
WideOpenThrottl's Avatar
42psi, 35/40 and 14cm2 housing.
Tim.
Old Apr 27, 2006 | 12:04 PM
whiteVLX's Avatar
Haven't seen over 32, yet, too little fuel pressure to push harder. I need to get another lift pump on in a bad way.
Old Apr 27, 2006 | 12:10 PM
noeardgoat's Avatar
I've only seen my go up to 20psi of boost. I have the stock wastegate w/ my stock turbo. Is something wrong here? My fuel pressure never dips below 17psi.
Old Apr 27, 2006 | 12:17 PM
Tiger Rag's Avatar
52 psi with BD twins previously with Edge Comp.
55 psi with Comp switched out to TST pm3.
I have head studs, but am nervous at 55 psi. I'm going to try and limit that to 50-52 if possible. Otherwise, I'll need fire-rings soon.
Old Apr 27, 2006 | 12:20 PM
gunracer1's Avatar
55#s with the pop offs set at fiddy on my 98, 50#s with a hx55 with a 19cm wastegated housing in the 97.
Old Apr 27, 2006 | 12:22 PM
signature600's Avatar
62psi limited (severly) by pop-offs...I saw ~70psi before re-adjusting the pop-offs
~48 in Valet mode
Chris
Old Apr 27, 2006 | 01:52 PM
Teddy Bear's Avatar
With a slid plate and 3k gsk i could hit 29pounds. I cut my plate to a #100 and put some 181 DVs in and can hit 40 if i get it in real hard.
Old Apr 27, 2006 | 02:39 PM
Willy91's Avatar
105Psi is the most I've ever seen S440/Big Brother combo
Old Apr 27, 2006 | 02:40 PM
sig600 how do you like that B2? i have a chance to get a b1/b2 kit fairly cheap (under $1000) with no pipes
Old Apr 27, 2006 | 03:00 PM
Buckshotmckee's Avatar
45psi with stock charger (HX35)!
Old Apr 27, 2006 | 03:02 PM
cowboys toys's Avatar
maxxed out the 60 guage so i really dunno. With a B2
Old Apr 27, 2006 | 03:18 PM
spyder3634's Avatar
stock hx35 with mods in sig = 42-45psi...not sure hard to look at the gauge while doing a doughnut
Old Apr 27, 2006 | 03:38 PM
zukgod1's Avatar
45-55 depending on the load.
If I'm crusing @ say 60mph and I slowly push the smoke peddle down by the time I hit 90 it's @ 50psi.. (about 3 seconds).
dan
