xmas present
Old Dec 15, 2004 | 09:29 AM
jeephauler's Avatar
xmas present
I will be getting gauges for xmas and need to know the best place to order a complete package with all needed tubing, senders, etc. I will be going with the IssPro pyro, fuel pressure and boost. Where is the best place to get them along with a 3 pillar mount with speaker.
Any recommondations on the guage ranges? Was thinking on the 60 boost, and 30 fuel pressure and 1500 pyro.
Old Dec 15, 2004 | 10:20 AM
RowJ's Avatar
Be sure yoiu specify ISSPRO EV's only. Ranges you mention are excellent. 60 psi on boost will get you to the 400's in HP if you plan on adding bomb's. 0-30 PSI is easier to read if you plan on staying near stock. You will need more than 60 psi, if/when you go to twins. Also, be sure you get bulb covers to match dash lights and would recommend red needle.
One good source is here; http://www.wildcatdiesel.com/. Sp w/ Rod (leave a message and he will c/b). He can tell you all you will need to prevent several trips to hardware store.
There are other good sources listed here under advertisers!
RJ
Old Dec 15, 2004 | 01:26 PM
BigBlue's Avatar
If you go with anything more than EZ, get the 60 psi gauge. The 30 is useless. Unless you like watching the needle peg itself with even the slightest touch of the throttle.
Old Dec 15, 2004 | 02:44 PM
Kyle Graham's Avatar
go with the 60 psi guage at least then you would never have to upgrade
Old Dec 15, 2004 | 03:10 PM
MCummings's Avatar
Heheh,,, never say never
Merrick
Old Dec 16, 2004 | 11:10 PM
PowerstrokeThis's Avatar
Unless your like Merrick and go off the deep end and in that case you'll need a 3 digit psi guage!!!!
Old Dec 17, 2004 | 05:25 AM
jeephauler's Avatar
Thanks guys I called Rod at Wildcat 2 days ago and left a message on what I wanted to see how long and how much. I still havnt heard back so Im gonna buzz him again today.
Old Dec 17, 2004 | 06:47 AM
JBlock's Avatar
Smokindiesel.com
I work oversea, so getting the right package at the house when i home in the USA is really valuable to me. I have found the kits that smokindiesel.com have assembled for me have worked perfect everytime. Guages, filters, Comps, etc.
Joe
Old Dec 17, 2004 | 11:08 AM
jeephauler's Avatar
Any of the other sponsors of the site have what im looking for. Rod just got back to me and said that he could get me the guages but not the pod or the lines and fittings for the fuel pressure. Said that they stopped doing the line kits because they were having too many problems getting them shipped across the lines.
Old Dec 17, 2004 | 02:09 PM
Moose10's Avatar
Do your own line and fittings for the fuel pressure gauge. I'll be selling my high flow Geno's Garage banjo bolts (one is tapped) as soon as my FASS arrives and I put it on. Check my gallery and read my last post in this attached thread regarding the FP gauge.
Also Rip Rook at www.sourceautomotive.biz is a good guy to deal with....maybe has some pods too ?
https://www.dieseltruckresource.com/...684#post548684
rstone
Nov 29, 2006 10:51 AM
DieselDiehard
Dec 23, 2005 08:22 AM
mr T
Dec 19, 2004 02:42 PM
Beavermike
Mar 5, 2004 04:31 PM
