Will adding a boost elbow help?
Old Jul 8, 2006 | 09:57 PM
SMOKNISB's Avatar
Right now all the truck has done is a 4" Silverline exhaust, Superchips tuner set to High-Performance level, and a BHAF. My question is: Will adding a boost elbow incease performance? It should add more boost correct? But if the boost goes over a set point, I think 20 or 21 lbs, wont it through an overboost code? If it does throw an overboost code, will it defuel or hurt performance?
Thanks
Old Jul 10, 2006 | 01:22 AM
SMOKNISB's Avatar
Anyone?...........
Old Jul 10, 2006 | 08:30 AM
displacedtexan's Avatar
Yeah you will get defuling. You would have to have something to keep the computer from seeing the extra boost (I love my 12v) I believe that a few companies make stand alone boost foolers, but I could be wrong.
Old Jul 10, 2006 | 08:37 AM
RustyJC's Avatar
I'm not familiar with the Superchips tuner, but unless it can reprogram the ECM to allow a higher boost before defueling and setting an overboost code, you'll need a boost fooler to go along with a boost elbow.
Most boxes such as my Edge EZ have a boost fooler function built into them.
Rusty
Old Jul 10, 2006 | 08:40 AM
I am 99.9% positive the the SC does not do boost fooling.
Old Jul 10, 2006 | 02:26 PM
SMOKNISB's Avatar
I am pretty sure it does not boost fool. I'm not really sure what it does. It came with the truck and SC does not really give a good explanation of what it does.
So if you do throw an overboost code, it will defuel correct?
Old Jul 10, 2006 | 11:27 PM
Ph4tty's Avatar
I beleive it actually alters the timing not the fueling. When I was overboosting and setting codes my black cloud would turn white. It wouldn't happen in the 20-30# range, but it'd stop me cold when I got boost into the 30's.
If you put an elbow on and it threw a code then you could just clear the code with the superchip. If you bought another box or programmer you could have the boost fooled and most come with the boost elbow too. Otherwise you can get a boost fooler from haisley machine for < $100
Old Jul 10, 2006 | 11:55 PM
SMOKNISB's Avatar
Ok...thanks for the info. So a boost fooler would work. Do you think it would even be benificial to add more boost with what I have now?
Old Jul 11, 2006 | 12:47 AM
CJ's Avatar
CJ
Not sure about the super chips, my van aken took me up to 26 psi w/ the boost elbow. With just the jammer III's I run around 30 psi. I got a boost fooler from BD for around 60.00.
CJ
Old Jul 11, 2006 | 01:36 AM
Ph4tty's Avatar
You need guages before you start to play.
Old Jul 11, 2006 | 08:43 AM
SMOKNISB's Avatar
Guages are next on the list.
Common
May 23, 2008 05:05 PM
dodgediesel
14
Dec 14, 2006 09:54 AM
RockcrawlingTJ
Jul 22, 2006 05:11 PM
triplenickel
Aug 23, 2005 04:01 PM
Palmetto_kid
Jan 16, 2004 02:21 PM
