Who uses scotty air
Old Jun 13, 2005 | 05:43 AM
Shovelhead's Avatar
Administrator / Scooter Bum
The UNI is a reuseable filter like the previous one used, but it has a Foam outer filter to help keep the big stuff out of the pleats.
Old Jun 13, 2005 | 09:38 AM
Scotty's Avatar
Top's Younger Twin
Just to clarify, there are no pleats. There is a coarse outer layer of foam that can be removed and cleaned. The inner layer is part of the main filter housing. Internally there is a wire mesh for reinforcement. Feedback has been that some folks are only cleaning the outer layer on the first cleaning because they are not seeing any discoloration or dirt on the inner layer.
I have hammered two single layer filters [in the real world] through snow, rain, dirt, dust and bugs from last summer til now with over 20K on them in the shaker I am testing. Oil analysis with the single layer is as good as anything out there. 5-7 PPM of silicon. The dual layer is getting the same results in the Scotty intakes.
Scotty
Old Jun 13, 2005 | 09:50 AM
Shovelhead's Avatar
Thanks for the update Scotty, as you can tell, I haven't had to service mine yet.
Old Jun 13, 2005 | 11:54 AM
Haulin_in_Dixie's Avatar
Scotty
Scotty do you think it is worth it to upgrade?
Old Jun 14, 2005 | 07:10 AM
Joe Diesel's Avatar
convinced me I'm picking one up this summer as soon as I get my $$ going
Old Jun 14, 2005 | 09:38 AM
Diesel Dave's Avatar
You won't go wrong with any of Scotty's little "inventions". I have had great results from my Scotty II and just recently installed a Smartfuel system on my truck due to less than ideal fuel pressures while towing. Just got back from my first trip with the Smartfuel and I gained 2 lbs of fuel pressure!!
Old Jun 14, 2005 | 09:44 AM
RowJ's Avatar
Originally posted by dsl21
...uni filkter also....I have had it about 6 mo....when do you clean it or do you just buy a new filter ....
Had mine about 4 months...20,000 miles. I have rotated it twice....loosen the hose attachment and rotate the filter in the housing to expose the fender inlet to cleaner surface. It does get black in that spot. Based on this, and how it looked, should not need cleaning for 40,000-50,000 miles.
RJ
Old Jun 14, 2005 | 10:15 AM
Scotty's Avatar
Top's Younger Twin
Yes as long as your bird is not attracted to the color red of the outer layer and it does not get jealous of the gray inner filter.
Scotty
Old Jun 14, 2005 | 12:00 PM
Scotty
In the near future I will get one comeing this way.... Thanks. I generally chase the bird out of the hood area, she can't compete with the Cummins fan
lezmark7
Feb 26, 2005 01:38 PM
Turbo Deeezle
Oct 1, 2004 01:00 PM
Crimedog
Jul 22, 2004 10:13 AM
Patrick Campbell
Dec 22, 2003 07:17 PM
hellotbone
Dec 9, 2003 12:32 PM
