where to hook up for "fuel source"?
Old Apr 14, 2007 | 11:12 AM
mx684's Avatar
can anyone tell me how that factory apiller cover is hooked on? i hate to just start prying without knowing how the clips are in there...
does anyone happen to have a picture they could show me of where to hook into the fuel source? im assuming the vp44?? but i have no idea where...i have read over these instructions and cant find anywhere where it says....
Old Apr 14, 2007 | 12:14 PM
Ph4tty's Avatar
I used fittings from vulcan performance to T the fuel line between the fuel filter and the vp44. There are tapped bango bolts availible for your fuel filter which can be used or there's a test post on the vp44 which can be used through a shrader valve fitting.
I'm not sure how much of my a pillar is factory, but theres two spring clips- one 1/2 way up, one 3/4 of the way up and there's a peice of plastic tubing on the top for alignment. I took it off just yesterday and it just took one good yank.
Old Apr 14, 2007 | 01:08 PM
Dr. Evil's Avatar
Just yank on the pillar from the top - it will come
I prefer to not use the VP-44 test port because it ties up the test port the following pics are for 00, 01, and 02 installs.
Guage setup with tapped banjo bolt:
Pic of tapped banjo bolt, needle valve, and line to guage:
Another of the same:
ALTERNATE Install using VP-44 test port:
Guage install inside cab:
If any of this is unclear, PM me your email address for a little more explanation.
Old Apr 14, 2007 | 02:28 PM
DodgeCowboy's Avatar
DTR's Cow Boss
Here is my setup using the vp test port I used a plain ol liquid filled pressure gauge that happen to be a white face to match my isspro.
Here Is The Line At The VP/ 6ft Of Hose Will Make It To The Forward Section Of The 4x4 Lever.
Here Is The Gauge Forward Of The 4x4 Lever.
Old Apr 14, 2007 | 06:25 PM
mx684's Avatar
Finally got everything installed...it looks great and works great..except the fuel pressure...i couldnt comeup with the banjo bolt or needle valve from anywhere local, so i had to order them offline....but i have the 1/8 line ran into the engine compartment ready to go..thanks for the suggestions and the pics. i really appreciate it..once i get my banjo bolt and needle valve i should be able to get it all finished up...ill try to get some pics in the near future..
Old Apr 14, 2007 | 07:41 PM
DTR's Cow Boss
One thing I am not sure if any one else has mentioned yet is as far as pulsing goes your less apt to have any pulses if you use rubber lines its the metal lines that seem to resonate worse. I have my needle valve if I remember wide open and have yet to have to snub it down to stop the pulses.
Old Apr 14, 2007 | 09:06 PM
Dr. Evil's Avatar
You could have tapped your current Banjo bolt....
Its a good idea to run your 1/8" tubing through some 1/4" tubing for abrasion resistance.
Old Apr 14, 2007 | 09:10 PM
DTR's Cow Boss
That too Dr. I just used some extra split loom were the key points were that mine would have rubbed a whole
Old Apr 19, 2007 | 08:45 AM
DTR's Cow Boss
MX you get every thing ricked away? on finding the last part you needed? If so how good is your fuel psi One this this past two weeks I have leard is a slipping clutch does wonders for keepin your fuel psi up as it dont load the motor as much but thats a whole new can of worms
Old Apr 20, 2007 | 05:59 PM
mx684's Avatar
i went ahead and ordered the banjo bolt from diesel manor..should be here today, but havent been home to check yet...i hope to get it all finished up this weekend...
PEAKSTRYDE
Oct 11, 2007 04:20 PM
satburn
Competition / Pulls / OffRoad
Jul 24, 2007 10:04 PM
RoadDiesel
Jul 11, 2007 09:31 PM
tbr473
31
Feb 12, 2007 12:47 PM
djgaston
17
Nov 8, 2005 08:15 AM
