When is it time?
Old Mar 25, 2005 | 04:39 AM
BDR2500's Avatar
When is it time?
I was just wondering when you need an aftermarket innercooler?
Old Mar 25, 2005 | 07:53 PM
pind's Avatar
Just about the time that you grenade the compressor side of your turbo, a new cooler would be a good idea.
About the time that while your truck is running, you spray windex or soapy water on the cooler, and it bubbles away like Jessica Simpson. A new cooler would be a good idea.
But, until then, as long as you keep the heat exchanger fins clean and clear, don't have any holes or cracks, and haven't grenaded your turbo. Your intercooler should be as happy as Larry.
Enjoy cruising, and peace of mind.
Old Mar 25, 2005 | 10:47 PM
ratsun's Avatar
I know of a few guys at or a little over 70psi of boost with the stocker but I dont know if they would benifit from a after market one? I cant say what the stockers efficency limit is but they can take a pretty good squeeze before they pop.
Old Mar 26, 2005 | 02:19 PM
BDR2500's Avatar
I know Haisley Machine has an innercooler upgrade, it's rated to 100psi. Their site says the stocker is only rated to 50psi.
Old Mar 26, 2005 | 05:03 PM
mkrenn's Avatar
50 or 70. The max I make is 34.
Stocker should work fer most people uhh?
03Big_Blue
Feb 26, 2008 08:44 PM
jc67
Introductions / New People
Feb 6, 2008 08:02 PM
k_butz
Feb 23, 2007 03:42 PM
taken5875
20
Jan 11, 2007 09:38 PM
