Whats wrong with this
Old May 17, 2008 | 08:12 PM
pickupman96's Avatar
beside this new turbo spools so slow i love it exept the egts. when im at 40mph, 1600rpm, and 3 to 3 psi im seeing over 900. At woy its over 1200. i checked for boost leaks and all i could find was the little hole on the boost elbow. what could it be
Old May 17, 2008 | 10:31 PM
JFlory's Avatar
I run the 64/71/13 and at 40 mph I only see about 650*.
I also have Mach 4's (150hp)stixs and the Juice/w Attitude Hot + Smarty. I see 1400 on WOT runs, but if I stay in it for more than a few seconds, the egts drop to about 1250.
My understanding was that the 65mm exhaust wheel was for more of a towing turbo. The 71 I have spools slow, but my truck is a manual, so it is easier to keep things in the ''much higher than stock'' power band.
Old May 17, 2008 | 10:45 PM
EBunger's Avatar
Is that with injectors alone? You also might be suprised what adding a muffler would do for spool up and egts.
Old May 18, 2008 | 08:08 AM
thats with the juice on level 6
Old May 18, 2008 | 01:28 PM
EBunger's Avatar
That is actually really good with throwin everything you got at it. Bigger turbos run hotter at cruise that is normal.
Old May 18, 2008 | 01:35 PM
Today I was going up a steep hill and i put it to the wood and it got to 1350. I have not seen it over that. Another thing I found when I was checking for boost leaks air was coming out of a little hole on the side of the boost elbow. Is it supposed to do this and if not how do i fix it
Old May 18, 2008 | 01:48 PM
06RAM2500's Avatar
Nope! If the hole is threaded you can run a plug. If not, replace the elbow!?!
Old May 18, 2008 | 02:03 PM
It has the end with the allen head screw and then on the side it has a small perfectly round hole about 1/64
Old May 18, 2008 | 03:26 PM
dieselrob's Avatar
Id be happy with those temps. If you thread the allen head in farther does the leak stop? Mabey its backed out to far.
Old May 18, 2008 | 04:33 PM
olddodgetruck's Avatar
that little hole is there to bleed off pressure to the wastegate. there is nothing wrong with that
dieselcrazy
May 9, 2004 07:08 PM
jman4567
May 1, 2004 10:13 PM
jman4567
Apr 22, 2004 10:15 AM
Kimrey
Jan 8, 2004 11:11 AM
silverram323
Oct 20, 2003 01:04 PM
