What more for 500 rwhp?
Old Feb 13, 2007 | 12:55 AM
Big Blue24's Avatar
Arrow What more for 500 rwhp?
I've got an Edge Comp, K&N intake, 4in Exhaust, Holley Blue pusher, Plenty of Clutch. What next to get to 500 HP? Is it possible with Edge Nozzles?
Old Feb 13, 2007 | 06:28 AM
dieselfan's Avatar
you need a turbo and injectors. a 62 or 64mm charger and some 150hp injectors should get close to 500hp. do a 64 and some 200hp injectors and you will be over 500.
Old Feb 13, 2007 | 06:38 AM
crobtex's Avatar
Don't forget the heads studs.
Old Feb 13, 2007 | 08:19 AM
BCSCUMMINS's Avatar
With a drag comp and 150’s and stock HX-35
Aggiehorsepower made 428hp and around 930 on level 3. 4 & 5 he lost power not enough air.
Old Feb 13, 2007 | 02:39 PM
displacedtexan's Avatar
What were the EGTs like?
Old Feb 13, 2007 | 06:01 PM
Beeram305's Avatar
Yeah, I'd say you need at least 150 hp injectors, but the HX is never gonna get you there. Dieselfan gave some good advice. My goal is a larger single, and 150-220 hp sticks on top of what I have, should be an easy 500.
Old Feb 14, 2007 | 03:29 PM
Big Blue24's Avatar
Would everyone say that 450 HP is the max with a stock head gasket? It seems that 400 HP is the max with a stock turbo if no NO2 is used.
Old Feb 14, 2007 | 03:32 PM
Not an apples to apples but Rick is over 500 on a stock HG, and I think Brian broke 500 as well. Not sure what GB did on his last dyno with the stock HG...
Old Feb 14, 2007 | 07:06 PM
jaymo's Avatar
Im over 400 with the stock turbo. But I should have the head back next thursday, with the full treatment. Im hoping for abit more.
Old Feb 14, 2007 | 07:12 PM
BigBlue's Avatar
I'm at the power you see now in my sig with a stock headgasket. I'm putting studs in this weekend though since I'm running water/meth now and I plan on upping the boost as well. The numbers in my sig were before water/meth and only at 40psi of boost. I think that with 50psi of boost and some water/meth (low concentration of meth) and some more timing I could break 500.
mouseguy
33
Sep 26, 2007 06:12 PM
powermad
21
Sep 16, 2007 07:48 PM
mstordahl
Feb 26, 2007 01:33 PM
quads4_life
36
Nov 7, 2006 06:20 AM
CTD2001
16
Jan 14, 2006 11:34 AM
