What Modification would you never do again?
Timbrens! Sorry believers. I do regret these puppies only because the unloaded ride is really harsh and uncomfortable. I should have gone with the air bags, at least then I could soften the unsprung ride a bit.
Wide low profile fat tire's running on 20's or 22's. You think that a 70 or 75 follows rutts. At least your not worring about ruining the rim in the rough stuff on 70-75 profile tires. Seen a few trucks with bent or damaged rims from running them.
Stacks are noisy for guys that live inside them like 8-16hrs a day. Even my rattlin VP drives me crazy on a 20 hr drive that seem to do every once and while.
Next worst mod, is anything from BD
Thanks Dave, I might be old, but at least I'm not looking old yet.
Must be the fancy hair cut.
Saw a young guy
last week with a bent 20in rim that was bent so bad the tire had a slow leak. Then completely ruined the tire as he drove on it for awhile. Had some fancy tire locks on the rim. Took us about 2hrs to change out the tire, all on a remote gravel road, in a snow storm and at -28 deg's C.
Lucky I had a floor jack in my truck
Must be the fancy hair cut. Saw a young guy
Even the laser cut DV...Which worked the best on my small 175 pump...I tried all combo of DV and the lasers work the best...But you have to really thighten up the AFC to control the fueling..
LC in 215 pumps...Bad news...They fuel to hard and smoke like heck...This is one mod on the 12v with 215 that is a negative..
In the CR world that is a different case...Seen alot of mods go on then removed....Darn computers...
Just a few inchs above the cab...You could veiw pics of my truck with stacks..
Never put anything but a triple disc torque convertor in, following with a good valve body that matches! Also domt waste your time with a Edge power puck, unless you just want to blow allot of smoke.
By the way the wife and I love my 8" stack!
Hetes another couple..never put any discount auto store batteries in! Put good ones in like interstate.
Edge easy was also a waste of money. Your better off saving up for a better power setting power programmer, like tst,quadzilla or edge drag comp.
