At what HP level should a person add a different lift pump on a 12v??
What point should a different lift pump be added such as a FASS??? I have a friend that has a 97 12v that dynos 600hp and he is thinking the fuel pressure from the stocker may be low. Anyone have some suggestions?
He should install a fuel pressure gauge to make that decision. The great thing about the mechanical pumps is that the more fuel you move, the higher the rpm, the more fuel they pump. If he sees a significant fuel pressure drop, then he might want to think about going a different route but I would stick with the stock setup as long as he can.
I know several people that have dyno'd in the 500-600 range on the stock 12v lift pumps with out a problem, and Joe D over on TDR got his 12v all the way into the 800's on fuel only with the stock lift pump.
What pressure is good for a mechanical pump??? I will have him hook up a gauge and check his.
He has DDP sticks, industrials twins with the k31, Industrial tuned pump, oringed and ported head, Helix camshaft.
He should be seeing around 18psi at idle and around 25 or so wide open. If it is below 20 psi wide open, try pinching off the return line to see if the overflow valve is worn out. Along with the lift pump being a limiting factor, all of the fuel lines and fittings are limiting. If he is seeing low pressure, it may make sense to redo the fuel system for less restricted flow rather than trying to put on a fass or something else.
JLo
Mar 25, 2008 04:51 PM
dodgemaniac
Jun 12, 2007 08:21 AM
Dave88LX
Dec 8, 2006 02:53 PM
morkable
Sep 22, 2006 04:16 PM
