have 14cm housing can i add different wheel
Old Mar 24, 2008 | 11:02 PM
JLo's Avatar
JLo
Hey guys, years ago i had a Banks Stinger Plus installed witch they installed a 14cm housing can i change the compressor wheel and if i could what size and would it help for towing and egts? The truck is a 97 auto.
Old Mar 24, 2008 | 11:35 PM
fattymak's Avatar
Yes you can, I put a 60 on mine from HTT. Pretty easy install, just need to do a little machining. I swapped a 14wg housing at the same time, probably lost 100-200 deg. Spool up is a little slower, I do get some minor surging with a light load under light acceleration with the edge on low. Not sure how it would behave on a 12 valve.
Old Mar 25, 2008 | 11:19 AM
HOHN's Avatar
I'd stick with the compressor you have, especially with an auto.
The 14cm housing is ideal, imo for that compressor size, and you don't want the additional lag of the bigger wheel because of your auto trans.
jmo
Old Mar 25, 2008 | 04:51 PM
CMooreBLKSMK's Avatar
I just added my 60mm upgrade from Gillet and I really like it. My egt's dropped a good deal and I'm pretty pleased. I'm still running my stock 12cm Exh. housing, but I would like to swap it out for a 14. No surging with mine yet, but I haven't towed with it yet.
Cory
andyr354
Aug 15, 2006 11:05 AM
Mcmopar
18
Jan 5, 2005 07:15 PM
caleb c.
Nov 25, 2004 12:04 PM
boughtadodge
May 31, 2004 09:20 PM
More Power
Dec 21, 2003 05:51 PM
