What do I have
Old Apr 10, 2008 | 07:42 PM
CODODGE2500MAN's Avatar
What do I have
How do I figure out what gears I have?
There are no markings that I can see on my rear axle.....
Thanks!
Old Apr 10, 2008 | 07:44 PM
Fishin2Deep4U's Avatar
What RPM are you turning at 60mph? 70mph?
Or you could lift the rear tire and count driveshaft revolutions....
Dave
Old Apr 10, 2008 | 08:06 PM
I'd love to tell you this....
But currently the truck is getting a new VP44, Fass 150, and DTT trans.
Keeping in mind I have 285's, what should I be running at 60, 70.
Old Apr 10, 2008 | 08:10 PM
IntakeRacing's Avatar
check your glove box. mine is written on a sticker on the inside of the glovebox
Old Apr 10, 2008 | 08:54 PM
Krob's Avatar
Call dealer with Vin number
Old Apr 10, 2008 | 09:01 PM
Ph4tty's Avatar
Glove box and inside the driver's door also if I recall correctly
Old Apr 10, 2008 | 09:04 PM
What're the benefit of 410's vs 355?
Old Apr 10, 2008 | 09:50 PM
HOHN's Avatar
4.10s have more grunt to the wheels. They will pull a trailer through the hills with less downshifting (if not bombed) or lower EGT (if bombed).
They also seem to have more options for aftermarket traction enhancement (lockers, LSDs, etc).
The difference between them is about 300rpm at highway speeds. Or, for the same RPM, you'll be going slower. For example, with 3.54s, you'll be doing ~71mph at 2K rpm. With the 4.10s, you'll be going only ~62mph.
Old Apr 10, 2008 | 10:00 PM
Purplezr2's Avatar
I believe that it says on the sticker under the hood also, look up at the latch with the hood open.
3.54 = better mileage
4.10= more power worse mileage.
Old Apr 10, 2008 | 10:08 PM
fmxr47's Avatar
check in the engine bay under the hood i believe along one of the sides ontop of the fender, mine is not on the glove box or the door, but under the hood says im running 3.55
Road Traveler
81
Nov 13, 2009 07:04 AM
Mark Thomas
Apr 30, 2006 08:20 AM
Intercooler
Jun 4, 2005 07:48 PM
routerguy99
17
Aug 11, 2003 12:21 PM
Nuttymopar
Apr 25, 2003 02:17 AM
