What can I expect?
What can I expect?
Hi All,
I am finally pulling the trigger and getting a Super B, Comp box, and 90HP injectors installed. What can I expect from it for just daily driving and pulling a 10K pound toyhauler?
Any suggestions on a better setup in the same budget? ($2500 installed)
Thanks
Thanks
daily driving will just be plain funner.. should run nice.. as far as towning.. you are now adding a fuel/timing box and injectors.. so you are gonna see higher EGTs, your turbo will be helping that out a bit.. but i would keep a close eye on that pyro when you hit some steep grade hills... if you are towing places other than the flats.
Totallyrad
Jul 19, 2011 07:41 AM
nasty01cummims
May 23, 2009 10:24 PM
Cumminsdieselboy
Feb 4, 2003 07:04 AM
clydesdale6
14
Jan 22, 2003 06:10 PM
