water meth install
Old Oct 24, 2007 | 06:51 PM
powermad's Avatar
would it be possible to drill and tap a hole into the piping just before the intake horn and put the boost gauge sensor there? and would i need to weld a bung if it was to thin of pipe?
Old Oct 24, 2007 | 10:49 PM
Bjans's Avatar
I would just buy a boost bolt and install it in place of one of the bolts on top of the intake plate and run the boost line up to the firewall and put a T in it and run one to the snow controller and one to your guage.
Old Oct 25, 2007 | 09:29 AM
XLR8R's Avatar
It's very easy to thread an NPT fitting into the aluminum intake - we've done it on the tailgate at events in just a few minutes...
Old Oct 25, 2007 | 10:30 AM
sledcrusher02's Avatar
boost point
as what bjans said use the boost bolt and split it.
Old Oct 25, 2007 | 06:29 PM
powermad's Avatar
xlr8tr i have the plastic cfm intake it only has three holes
Old Oct 25, 2007 | 06:38 PM
XLR8R's Avatar
How thick is it?
Old Oct 27, 2007 | 01:04 AM
powermad's Avatar
im not sure it has three pre drilled and tapped holes but they are reinforced and i dont think it would be possible to tap into it. i was thinking i dont know if i need 2 nozzles. what do you think
Old Oct 27, 2007 | 11:03 AM
XLR8R's Avatar
You need those other two threaded ports if you want to have more than a single stage of water/meth... why don't you just Tee off of the remaining port for the boost gauge & Hobbs switch?
Old Oct 28, 2007 | 10:36 AM
RowJ's Avatar
Two 625 nozzles here. Not too much, by any means.
Dynos up to 60 hp ...depending how you mix your fluid and how you set up injection pump.
Probably around 40 hp with 20% washer fluid and full pump pressure
RJ
Old Oct 28, 2007 | 08:02 PM
taken5875's Avatar
why don't you use the boost test port on the driver side of the motor for your boost gauge or for the feed back for the meth the test port is 3/4 but you could size it down
Old Sep 23, 2008 | 12:29 AM
BlackCloud#2's Avatar
I put my meth kit on two months ago and the pump quit working already. I haven't found a break in the wires to bad connections. What would cause this?
Old Sep 23, 2008 | 08:48 PM
powermad's Avatar
are you running the pump dry? that will make the pump go out faster.
Old Sep 24, 2008 | 09:04 AM
NO not at all, it worked fine then just quit working.
Old Sep 24, 2008 | 09:13 AM
RowJ's Avatar
Hot wire pump to battery....see if it's your wiring (something loose) or really is the pump!
RJ
jdpiii
Jun 19, 2008 07:34 AM
trik396
55
Jul 23, 2007 08:35 PM
omaharam
Jun 16, 2006 01:47 PM
got...DIESEL?
Jan 16, 2006 05:43 PM
wannadiesel
Jan 19, 2005 05:33 PM
