water meth install
Old Oct 13, 2007 | 12:17 AM
powermad's Avatar
water meth install
i am putting the snow performance kit on my truck and theres a 18 inch tygon tube and i cant figure out what to do with it, and it isnt anywere in the instructions.
Old Oct 13, 2007 | 12:33 PM
powermad's Avatar
some buddy has to know what it is... please help
Old Oct 13, 2007 | 02:22 PM
rockjeep73's Avatar
whats a tygon tube?
if I knew what it was I could probably help you.
Old Oct 13, 2007 | 05:57 PM
BigBully's Avatar
I think it should go from a Boost source somewhere to the controller
Old Oct 13, 2007 | 10:06 PM
rockjeep73's Avatar
ya, on my truck I just drilled and tapped another hole in the intake horn, right by the nozzles and threaded in a barbed fitting that the rubber hose attaches to.
Old Oct 13, 2007 | 11:38 PM
powermad's Avatar
what kind of boost are you running? im worried that with a lot of boost the line will blow off. because the line for my boost guage is heavy duty plastic
Old Oct 14, 2007 | 12:02 AM
rockjeep73's Avatar
I have ran it as high as 50psi without a problem.
Old Oct 14, 2007 | 01:17 AM
powermad's Avatar
ok you win, im running 40 so i shouldnt have any problems. thanksfor the feedback
Old Oct 14, 2007 | 08:59 AM
BigBully's Avatar
Mine has blown off before so I just put a little wire tie on it as a clamp and I hit 50psi all the time and it has not blown off since the little wire tie was installed.
Old Oct 14, 2007 | 04:14 PM
powermad's Avatar
i am going to be running duel injection and i only have 3 holes in the intake. i already have my boost line running to my guage. so the problem is will i be able to tap into my actual boost line with a t fitting or will that mess with my boost readings?
Old Oct 14, 2007 | 07:39 PM
rockjeep73's Avatar
But a "T" in the intake horn and run the controller and gauge off of it like you said. It wont effect the boost reading.
Old Oct 17, 2007 | 11:13 AM
powermad's Avatar
oh ok i will try that thanks
Old Oct 17, 2007 | 12:14 PM
RowJ's Avatar
I tapped another hole. Should be plenty of room for it. And mine holds up to 65 psi with no problem.
But the 'T' should work fine as well.... being a closed system.
RJ
Old Oct 20, 2007 | 12:52 PM
powermad's Avatar
i have the plastic cfm intake. if this was a stock or a metal intake i would drill another hole. i want to run 2 nozzles and need to have a boost guage and i also need the rubber line for the water injection. is that the water injection farthest and the boost closest and then what is the line in the middle for?
Old Oct 21, 2007 | 09:54 AM
RowJ's Avatar
Closest line in pic is boost gauge line.
Second closest is the boost line for operating feedback to Snow's injection controller.
Line & fitting came with the kit!
RJ
