Wastegate???
Old Apr 15, 2006 | 10:54 AM
Geico266's Avatar
I have an HX and I just block off the waste gate tube at the turbo. The most boost I get is 30 PSI.
Old Apr 16, 2006 | 12:18 AM
G-NOTE's Avatar
Wink
I am going to take pictures of my setup, but it worked great...
I bought :
*2-hook to eye 1/4" turnbuckles
*1-S hook clevist
*1-2-1/2" extremly hard spring
I installed the "s" hook around the wastegate actuator arm, then extended both of the turnbuckle's about 4 threads from being fully extended. Then I attached the first one directly to the "S" hook using the turnbuckle eye side. I then attached the hook side of the turnbuckle to the spring. On the opposite side of the spring I attached to other hook side of the second turnbuckle. Finally I bolted down the eye side of the second turnbuckle to the alternator bracket. I previously drilled the bracket and ran a #14 sharp point pan head screw in it. I also bent the eye side of one of the turnbuckles about 30 degrees so that when it was attached to the alternator bracket it was a streight shot at the wastegate.
I am boosting about 29-30 psi with the first turnbuckle tightened all the way in, I'm sure it will boost more if I tighten the other turnbuckle but then it will be unefficiant and will probibly grenade...
sallyman1
Feb 10, 2008 06:17 PM
ataboy9026
Feb 22, 2006 05:09 AM
MoparRiggan
Oct 13, 2005 11:54 AM
dieselcrazy
Mar 22, 2003 08:21 PM
Copenhagenjunkie
Dec 27, 2002 05:45 PM
