Warning: Potential Stupid Idea
Now...I have an idea... It may or may not work, I'm not sure and want some input on it. I have read on several threads that disconnecting the map sensor when you have the edge comp will make mass quantities of smoke. On the assumption that this works like I think it does. My Idea is to basically splice a switch on to the map sensor wire. By doing this you can control, in-cab, the ability to blow alot of smoke. Please correct me if I'm wrong, or give opinions if I'm potentially right.
wap
Sep 11, 2006 12:44 PM
jrussell
Jun 14, 2006 11:04 PM
