VP problem?
Old Oct 15, 2005 | 02:19 PM
upersleder's Avatar
VP problem?
a little background... got gages in march just before i went to texas, found i had a bad lift pump and experienced the dead peddal thing on my way to texas with my superchips tuner installed. i returned the vehicle to stock and took it to the dealer to change the lift pump, which they did, but then my tuner would not work. when i got home, took it to the dealers because i had the 0216 code, the texas dealer erased the same code also. the dealer erased the code and made an appointment to check it out, brought it back a few days later and he didnt do anything because the code didnt come back.
NOW i got my tuner repaired and recieved it yesterday, installed the program and shortly after i get the dead peddal syndrome again on a hard take-off. fuel PSI droped to about 7, if i stay in the throttle it just does nothing, if i back out of it it catches up and goes fine, i checked and have the code back again. the boost still does not go above 20PSI with the tuner installed and everything seems just like before except for a bit more pull on the low end.
so, is this a VP problem, or something with my tuner?
Old Oct 15, 2005 | 02:23 PM
CTD2001's Avatar
VP sounds like it is one its way out, mine did the same thing
CTD23
Jun 9, 2006 09:32 PM
Checkmate
Mar 5, 2005 08:36 PM
callum
Nov 21, 2004 07:04 PM
dogman
Dec 27, 2003 07:06 PM
