Veggie oil and booster kits???
Has anyone used, or heard of anyone whose ran veg with any kits? what/which one works best?
also any idea if its best to use synthetic or regular oil with the veggie?
BTW: I'm running a stock '96 and looking for fuel efficiancy more than anything (a few more horses would be pretty sweet too
Ive got a homebrew kit but its similar to the frybrid design. Id recommend them since the setup is designed well.
I opted to make up a pair of smaller tanks and put them under the bed instead of having it in the bed taking up space.
If you make your own kit, youll need a heated tank, heated fuel filter, hose in hose heaters and a flat plate heat exchanger. you can make your own heater with 1/2" coiled aluminum tubing. Id recommend a vormax heated filter. You can get flat plate heat exchangers on ebay.
cool thanks for the reply, I'm up on the veg kit stuff (I'm going plantdrive). I was wondering if anyone has used a high performance computer/chip/kit (ie: banks kit) to there truck that was already running on veg.
ccoop769
Oct 31, 2007 11:10 PM
kawi600
Aug 23, 2006 11:23 AM
