valve body
Old May 25, 2009 | 11:00 PM
dodge_24's Avatar
valve body
my next step on my truck is a valvebody i would like to do it myself does anybody have any tips or is it too hard for a weekend job need any special tools. would royal purple help any or keep factory oil
thanks guys
Old May 25, 2009 | 11:25 PM
oldblues's Avatar
hi
use walmart atf+4 works great !
use the transgo kit and drill the hole sizes in the middle range of the speck .
mine works great .
take your time and read the instructions over till you understand them !
Old May 26, 2009 | 09:44 PM
williala's Avatar
Just finished putting a Transgo shift kit in this evening. Its not that hard. No special tools required. I can't overstate the advice to take your time. Read and re-read the instructions, they area little vague. Keep in mind the instructions and parts included may be for more than one model of transmission, so keep in mind that fact while you are doing the task. Don't be frightened if there are extra parts left over.
Give your self plenty of time and work space, it will probably take more than you originally thought. Keep things clean with plenty of spray parts cleaner.
Old May 26, 2009 | 10:10 PM
GSP's Avatar
GSP
I installed a SMR kit in mine, I have used Transgo kits also. The SMR instructions explains what each step does or improves or upgrades. Pretty good instructions
Take your time, dont try and get it done in a set amount of time, read and reread the instructions, Have a nice clean large work bench, and again take your time
I like my SMR , nice quick, firm shifting and more oil volume to the TC lockup
My friend has a trans shop and we compared SMR with the Transgo instructions
Rick
Old May 26, 2009 | 11:25 PM
J.Suplanski's Avatar
trans
I have a Suncoast and use AMSOIL ATF Synthetics, ans a Mag-Hytech trans cover larger capaciety
Old May 27, 2009 | 06:04 AM
J OOPS's Avatar
I agree, read the instructions and reread. My .02 use synthetic atf fluids well worth it. Also install a drain plug kit in your tranny pan at the same time.
I have had no problems with my tranny after installing the transgo kit.
Old May 27, 2009 | 08:03 AM
welder 59's Avatar
transgo works great. I agree with drilling to the mid power range. Take your time.
Old May 27, 2009 | 07:16 PM
dodge_24's Avatar
whats the diff between a shift kit and a aftermarket valvebody i had heard that a shift kit for a diesel doesn't help u and its better to buy a aftermarket valvebody
trying to make it hold the edge comp hot
shooting for 350-400 hp
Old May 27, 2009 | 10:04 PM
GSP's Avatar
GSP
"whats the diff between a shift kit and a aftermarket valvebody"
Shift kit you build your self- Aftermarket VB someone else built it with a kit and sold you the whole VB
Old May 27, 2009 | 11:00 PM
dodge_24's Avatar
can u get the same press with the shift kit as the valvebody.
i have to ask questions before spending money
thanks
Old May 28, 2009 | 12:08 PM
GSP's Avatar
GSP
Yes, and line pressure can be adjusted , The kit intructions will explain
Old May 28, 2009 | 06:37 PM
dodge_24's Avatar
thanks for the info
just wondering why everybody pays for a built valvebody when the shift kit is so cheap
will it handle the edge comp box
Old May 28, 2009 | 11:21 PM
raychem's Avatar
Originally Posted by dodge_24
thanks for the info
Because contrary to popular belief, not every transmission builder uses a off the shelf shift kit. Most builders have the valves made for their use with different profiles and springs. Also, some tranny builders will not accept your VB as a core when you do a shift kit since the transgo shift kits make some modifications on the VB that are not used by them. So, in a nutshell, shift kits are good and as stated, they are a lot less. But if you plan on building your tranny in the future, contact your builder of choice and make sure they will accept your VB as core with a trans go shift kit installed. It will save you from being charged a core later.
Richard
Old May 29, 2009 | 10:03 AM
BigErksG2's Avatar
a 47re valve body is a 47re valve body. the "heavy duty" ones you buy for $400+ are stock valve bodies with some holes bored out and a spring swap ( a shift kit already installed). if youre taking the valve body out yourself, might as well do the shift kit yourself too!
Old May 29, 2009 | 06:25 PM
dodge_24's Avatar
what are u running in your tranny BigErksG2
would like to run the edge comp with no problem
thinking of shift kit and a single disc convertor
will tranny hold up
thanks
Trooperthorn
Jan 7, 2011 12:55 AM
jj3500
Jul 12, 2009 03:59 PM
12ValverDave
Nov 15, 2008 03:50 PM
Luke S
Nov 30, 2002 10:57 AM
