Valve Adjustment
Old May 10, 2006 | 12:04 PM
BlueDevil's Avatar
Question Valve Adjustment
I am going to the Cummins house in a week or two so I can have my valves adjusted. Is there one way better than another to have the valves set so that it runs better and/or cooler? Thanks.
Old May 10, 2006 | 12:07 PM
BigBlue's Avatar
IIRC, set them up a little on the tight side. You do know the valves don't need to be done until 150,000 or so miles.
Old May 10, 2006 | 12:16 PM
BlueDevil's Avatar
Well I am almost to 121K and with the way this truck has run since I bought it, I figure it could probably use it.
Old May 10, 2006 | 12:45 PM
B.A.Ram's Avatar
Blue didn't you adjust your valves at 90,000?????????
Old May 10, 2006 | 01:03 PM
BigBlue's Avatar
Nope. We spent all day working on your heap.
Old May 10, 2006 | 05:37 PM
Tiger Rag's Avatar
How you liking the 1.5's? Did you get them in yet?
Old May 10, 2006 | 06:52 PM
B.A.Ram's Avatar
touche' my friend.....Matt I'm going to put them in this weekend. Last weekend we went fishing Sat. morning, however; the trip turned into a weekend long trip because you can't quit when your catching fish right??
Old May 10, 2006 | 09:26 PM
Mike D's Avatar
I set my valves at 7 intake and 17 exhaust. Cummins says 10 intake and 20 exhaust plus or minus 5.
Old May 16, 2006 | 12:50 PM
BlueDevil's Avatar
What will this or setting them tight do?
Old May 16, 2006 | 01:04 PM
G1625S's Avatar
Tighter valve clearance settings take more advantage of the cams' lift and duration. In the case of the cummins (especially the older 12vers) the cam is extremely lame, so we try to get every last bit out of that profile by setting the valves tight. Too tight and the valves will not close completely once hot. Best case scenario is the engine will lose compression, but valves will start kissing pistons as well!
Old May 16, 2006 | 01:39 PM
BlueDevil's Avatar
What settings do you recommend for an 02 HO?
Old May 16, 2006 | 06:03 PM
Mike D's Avatar
I would set it to stock Cummins specs.
Fishbait
Nov 23, 2009 11:21 AM
ConnerCop
May 5, 2009 07:48 AM
dhughe2
13
Dec 6, 2006 07:40 AM
bulthisl
Mar 22, 2003 07:01 AM
blackboat
Nov 8, 2002 06:32 PM
