VA Issues
Old Nov 14, 2005 | 06:47 PM
chaos24valve's Avatar
VA Issues
My Check engine light stays on and it seems as if I dont have the full power of the chip, I still have major turbo lag and my low end just seems the same, now going about 80 on the freeway the truck was a monster, I am thinking something isnt plugged in all the way but I am not sure. And what is the little orange this for that is right next to the main connector on the harness, it doesnt say in the instructions!!! Thx. CJ
Old Nov 15, 2005 | 07:30 AM
farmer dave's Avatar
It sounds like the VA isn't running right. I would give them a call and see what they say. You may have to send it in to get reprogrammed to have it work right. The orange things on the connectors are locks. When you have the connectors attached you need to push the orange thing in to help lock the connectors shut. You might want to try this before calling VA, it could be that the connectors aren't staying connected.
Old Nov 15, 2005 | 07:39 AM
getblown5.9's Avatar
no he means the orange connector on the 3 or 3 wires that comes out of the VA box. i have no idea what thats for, i never hooked it up on my truck and it ran fine with the VA.
i have a check engine light now with my comp. i forgot to check the codes this mornign tho to see whats wrong
Old Nov 15, 2005 | 11:10 AM
Dieselcamper's Avatar
I had the same problem when I first hooked up my
van Aaken V5. Turns out I didn't have the MAP connector
from the van Aaken pushed all the way in for a good
connection. Reconnected and cleared the codes at Autozone
and no problems for the last 9 months.The extra orange/black
plung on the van Aaken is for the optional on / off switch.
Old Nov 15, 2005 | 02:37 PM
Everythings fixed. After I turned the truck off and just sat around thinking for a little bit, then decided to start it again, and i had no codes or anything, and the check engine light went off as well, so now I am set, and it seems that there is a considerable amount of power now! Its great. thats all there is to say. I love it and goes VROOM. Thanks for the input guys.
pappyman
Dec 11, 2002 03:37 PM
crossy
Dec 8, 2002 05:14 PM
crossy
Dec 5, 2002 10:42 AM
TXTad
Nov 11, 2002 12:39 PM
