Upgrading 47RE
Old Feb 1, 2013 | 03:53 PM
Silver R/T's Avatar
Upgrading 47RE
I already have TransGo shift kit and ATS deep pan that will go on 47RE, what else should I upgrade while shift kit and new pan are installed?
I'll be putting on Edge J/A on it as well later this year.
Old Feb 2, 2013 | 01:51 PM
bigsmokey's Avatar
the torque converters are a week point in these trannys but that involves removing the transmission to replace. The factory torque converters can't handle the extra power the edge is gonna add. i did a converter and valve body to my tranny and it is holding the power just fine, and i am not easy on it either.
Old Feb 2, 2013 | 02:01 PM
rattlerbob5.9's Avatar
If you are going to give it the full power of the edge j/a it might be a good idea to give your tranny a general rebuild along with a new convertor and valve body capable of doing the job.
If you do the convertor as you should the trans has to come out anyway so for a few more bucks and a little time do it right the first time and be done with it.
Old Feb 11, 2013 | 10:49 PM
Mike Holmen's Avatar
The Guru
Depending on power goals, you could upgrade some of the 47RE parts with the newer beefier 48re parts. I would also crank up the line pressure a bunch and add extra clutchs/steels to the front/rear clutch packs. I would also add a few extra clutchs/steels for the OD unit.
http://www.transmissionpartsusa.com/...ts_s/17983.htm
Billet shafts are also a decent upgrade and same goes for a decent hi stall triple disk to help spool the bigger turbo(s)
Old Feb 12, 2013 | 06:53 PM
gorms's Avatar
I mean, while you have the valve body out anyways...
Old Feb 15, 2013 | 09:30 AM
The Guru
My stock 47RE with the valve body upgrade, lasted me 10000miles towing my RV. I ran edge ez and 50HP injectors at the time.
I just killed my fourth 47/48RE transmission last week, doing a burnout tryout my new dana 80 ARB unit that I just installed. I typically get 75000 to 125000 out of a transmission
Old Feb 16, 2013 | 07:44 PM
ehohn's Avatar
10 Year Member
quick question, pulling my 47re now. how do ya get the tourge converter bolts off the flex plate. what size are they?
Old Feb 18, 2013 | 11:26 AM
The Guru
There is a two bolt cover on the bell housing adapter plate, just under the turbo. Right above the plug for the manual baring tool.
If my memory is correct, I think that they are 9/16 grade 8, NF thread pitch. I can't remember is there is five or six bolts. The torque convert should be able to move back and forth 1/8in, prior to removing the transmission.
You can also get access thru the starter hole, but its very busy on that side.
Old Feb 18, 2013 | 12:02 PM
joem's Avatar
Have one person spin the engine with a huge flat blade screwdriver and you hit the bolts- it went shockingly quick when i did mine- and when the trans is about 2" back make sure to saftey wire it so it doesnt fall off the input shaft. I 100% love my goerend 900/400 converter!
Old Jul 13, 2013 | 09:37 PM
tughillnut's Avatar
Smile
may I recommend a new billet flex plate while you are there. I made the mistake of not upgrading while I was already in there and I most unfortunately one day on the way to work pulled out onto the highway and just a little bit of peddle and pop. I twisted the middle of the stock flexplate right out of the outer ring. I got lucky nothing else was damaged. just something to think about.
Old Jul 14, 2013 | 02:29 PM
joem's Avatar
really? how much power are you running? I already slip my over drive clutches and my flex plate is still ok
Old Jul 19, 2013 | 01:03 AM
taken5875's Avatar
With the truck in my sig I also snapped the center out of my stock flex plate. Probably 425-450 hp I would guess
thehemikid
Feb 25, 2021 12:45 PM
chadpatten
Mar 22, 2007 09:50 AM
Munchies
Oct 19, 2006 06:09 AM
Rocketman
Dec 28, 2002 01:06 PM
