Update On PE Pump
Old Sep 1, 2003 | 12:07 PM
BigBlue's Avatar
Update On PE Pump
Got some good news. I went and hooked a mechanical FP gauge (0-100 psi) up to the schrader valve (had to go back to the stock fuel line) and it read 22 psi at idle. Cool. So I drove around with it hooked up and checked the readings at various points along the way (the hose on it wasn't long enough to strap to the windshield). It still read 22 psi. Sweet. Went home and hooked up my digital FP gauge to the same line and went for a drive on the same trip. It started off at 17.6, but by the end of the drive, it was flashing EEE (meaning the pressure was to high). Phew. At least now I know my pressures aren't off the chart. I'm going to get a longer hose and strap the gauge to my windshield and drive around and see if the needle even moves (hopefully it's not a bad gauge). Now the only problem I have is this fuel leak (which I can't get sealed so I'm gonna have to buy a new fitting) and the problem with the trigger wire. Could I just wire it to a switch in the cab so when I get in the truck, I can turn it on and off?
Old Sep 1, 2003 | 05:59 PM
SjLingenfelter's Avatar
Re:Update On PE Pump
Woudnt it also be a anti theft deal?
Old Sep 1, 2003 | 08:09 PM
Stamey's Avatar
Blue,
Tell me again why you aren't using the factory fuel pump hot wire to trigger the PE.
I thought you got the fuel pressure down to 13 psi by cutting the spring. ???
Chris
Old Sep 2, 2003 | 12:11 AM
BigBlue's Avatar
It went down to 13 on the digital gauge, but it shot back up to over 30. After discussing it with PE, they said there is absolutely no way the pump can do over 25. The motor just physically can't pump that much pressure. It's to small. The most they got out of it was 25 and that was with the bypass completely shut. That's why I installed the mechanical gauge. Just to see if the sender was shot. Turns out it was.
The reason I'm not using the trigger wire from the stock lift pump is cause the ECM for the pump is dead. It died while I was trying to prime the truck. Yall think that maybe after being primed so much, the lift pump relay quits working for a period of time to allow the pump time to cool off or something? Kind of like a fail safe mode or something?
Old Sep 2, 2003 | 07:19 AM
Stamey's Avatar
You may have blown a fuse, but should not have burnt anything out. How were you priming the system?
The lift pump wire is hot when you turn the key on, for about 15 seconds, then only gets hot when the engine is turning or is bumped and stays on for about 20-25 seconds. I suggest you at least hook up a test light and observe when the wire is hot. If it is not hot, check fuses.
You still looking for the regulator?
Chris
Old Sep 2, 2003 | 03:21 PM
BigBlue's Avatar
Maybe on the regulator. I was priming it by bumping the starter. It was working fine till I went to start it one time and it quit working. Hooked a test light up to it and bumped the starter again, still no power to the wire. I was wondering if maybe I overheated the relay and it quit working to protect itself. The only thing I could find in the under hood fuse block that relates to the fuel pump is the fuel pump relay. That's it.
DFD536
Aug 18, 2006 11:38 PM
TEXASTURBO
Mar 14, 2005 08:46 PM
Scotty
19
Jan 16, 2005 08:41 PM
MnTom
Aug 25, 2004 11:19 PM
