uh oh.........
Old Aug 30, 2006 | 07:41 PM
blackdiesel's Avatar
Registered
uh oh.........
dunno if this is in the right forum, if not i apologize and please move it
now i got my pup today (pics up later) and i took off real easy coming home. (dont do this very often) and i herd this awful knock. It wasnt really loud, but enought to make me paranoid. (sp?) anyways, it seemed to get worse as i got home. it dosnt do it in neutral setting still, or in neutral when im driving. i can rev it up in neutral and it dosnt do it, but as soon as i put it in gear its "knock knock knock knock knock" varies of course with the rpm.
Please tell me its the 2k tranny instead of the 8k motor.
oh and my trans dosent have working syncros. Ideas??
Old Aug 30, 2006 | 07:46 PM
displacedtexan's Avatar
Does it matter if the clutch is in/out? My first guess is something with the clutch...
Old Aug 30, 2006 | 07:47 PM
Registered
well i got that stupid LOUD double disk. But it only happens when im in gear and moving
Old Aug 30, 2006 | 07:57 PM
Dusty Ratcliff's Avatar
"stupid LOUD double disk" .................so I'm not the only one who feels that way!!!!! LOL sounds more tranny related to me??? let us know, Dusty
Old Aug 30, 2006 | 08:33 PM
TxDiesel007's Avatar
Bryan
i had that happen to me when i had my old F250, it was exactly what you said, and it turned out being that the clutch went out. Now i dont know how hard you are on your dual disk, but in my old ford the springs came out and the disc was cracked, and i heard the same knocking in second third and fourth. Im not certain what went out, (i wasnt into mechanics at that time ) but i knew it was in the tranny..
Rick
Old Aug 30, 2006 | 09:26 PM
Ram2Pete's Avatar
is it a 5 or 6speed my 6speed is doing this and from what I have read it might be the bearings in the trans but I havn't got it out yet
oh and mine does the loud knocking in every grear sept 5th
Old Aug 30, 2006 | 09:33 PM
Registered
shes gettin pretty bad. I had dad ride in it while i drove and he said it was the trans too. He thinks its a bearing. i guess ill drive it till she blows. then park it in the shop and drive the '57 till i get a rebuilt. ya play ya pay
and i play hard
Old Aug 30, 2006 | 10:01 PM
Ram2Pete's Avatar
you may want to kep the driving to a min as the 6speeds are no longer made and I think are getting harder to get new ones/parts for one
link I found for some parts http://www.quad4x4.com/NV5600%20parts.htm
also do a search on here about the 5600 and see if it comes up with anything I'm still looking at my options
Old Aug 30, 2006 | 10:04 PM
How long has it been since you rebuilt it Brian? (Didn't you just rebuild it?)
Old Aug 31, 2006 | 07:13 AM
Registered
yeah is only been about a year. but i couldnt press the lower shaft apart so i couldnt replace those 2 syncros. and it all went down hill from there
Old Aug 31, 2006 | 01:03 PM
Diesel-Dan's Avatar
UM....have you checked your U-joints lately? Just a suggestion......
Old Aug 31, 2006 | 01:07 PM
haloman's Avatar
Maybe it is a sign that you need a 10-speed and ditch the 6 for all that hay you haul.
Just another option maybe.
Old Aug 31, 2006 | 04:53 PM
Registered
acually, that might be it. Dad also brought that up. ill put er up on the lift and check her out
Old Aug 31, 2006 | 05:15 PM
Diesel-Dan's Avatar
Son...if they are popping that loud....you wont need a lift to check them! Unload the drive train and just wiggle the drive shaft back and forth!
Old Aug 31, 2006 | 05:39 PM
Registered
i dont crawl under anything anymore. everything that requires me getting under a vehicle is getting on the lift.
went out and drove it again. im beginning to think its the clutch. i may have to see if peter has had a problem like this before....
