Twins Bracket?
Old Jul 14, 2005 | 10:23 PM
12vordie's Avatar
Twins Bracket?
How is the bottom turbo supported on a twin setup, it seems that there should be some kind of bracket to support it? I will be running an ht3b on bottom and don't think it is supported by the upper turbo alone, or is it.
If any can tell me what are the sizes of the exhaust side and inlet side of the ht3b so I can go ahead and round up some plumbing? What is the differance in using an external wastegate or a blow off valve.
Old Jul 14, 2005 | 11:40 PM
DesertRat93's Avatar
My HT3B is supported with a bracket I built between the exh. manifold and the motor mount bracket. I thought the same thing, too much weight for the top turbo and manifold. Exhaust turbine is 3" x 2" in, 5" out. Compressor is 5 1/2" in, 3 1/2" out. 3/4 pipe thread on the oil drain.
Old Jul 15, 2005 | 02:20 AM
1320's Avatar
I built a bracket off the manifold....and off the bottom to the block.
Old Jul 15, 2005 | 08:27 AM
apwatson50's Avatar
A blow off valve is for the fresh air side, mostly for gassers since they have a throttle body and when its closed after WOT there is a lot of pressure that builds up that needs released. Wastegate is on the exhaust side and lets excess exhaust around the turbine wheel.
Old Oct 23, 2006 | 11:34 AM
AZGEARPRO's Avatar
does anyone have pics of there bracket setup for the 12v and HT3b?
Old Oct 23, 2006 | 02:29 PM
Jambbii's Avatar
I made a bracket to bolt on to my transmission heat exchanger mount. Really hard to see with the pic I have.
Old Oct 23, 2006 | 02:43 PM
hertz's Avatar
www.sourceautomotive.biz sells the piece or pieces you are looking for
Old Oct 23, 2006 | 03:04 PM
bnold's Avatar
Beat me to it!!
Old Oct 23, 2006 | 03:30 PM
RowJ's Avatar
Originally Posted by DesertRat93
.. I thought the same thing, too much weight for the top turbo and manifold.
I'm not sure it's the weight so much as the length of the arm created and the potential for side load?
BD has a bracket the bolts sideways to the block. It appears primarily to reduce lateral sway but may end up supporting some download!
RJ
dodgediesel
ABDTR #5
Oct 18, 2011 09:22 PM
dodgediesel
ABDTR #5
496
Oct 16, 2011 04:33 PM
dodgediesel
17
Apr 5, 2011 11:21 AM
aggiehorsepower
Jan 16, 2007 10:40 PM
Stock 02
28
Sep 24, 2006 11:09 AM
