Bottom turbo mounting bracket for twins
Old Jan 16, 2007 | 06:34 PM
aggiehorsepower's Avatar
I was wondering on the bottom turbo mounting bracket from source automotive for twins how the oil drains into the block. Because that piece of pipe just ends and doesn't go all the way up to the block.
Old Jan 16, 2007 | 07:42 PM
TxDiesel007's Avatar
From the bottom bracket
where the turbo bolts up there is an area where u bolt down to the turbo drain, its built right in, all u need is a gasket and two 10 mm bolts. From the bottom of the drain, dependin on ur truck, u just run it to either the frost plug, which is much easier, or u have to drill a hole in the oil pan, as i had to with my 96.. Look at the pic, and the J part of the bracket u see is actually the oil drain...
Rick
Old Jan 16, 2007 | 07:54 PM
well i have the piece already and i have a plug in the block i need to pop out but what do I hook up to the end of that then how do i hook it up into that hole where the freeze plug was?
Old Jan 16, 2007 | 08:46 PM
If u are runnin one of rips brackets
The bottom part of the drain will go towards the oil pan, and from their u just run a rubber line to the frost plug and thats it,
Rick
Old Jan 16, 2007 | 08:47 PM
cyric's Avatar
Once you pop out the plug put in a straight o-ringed nipple (available from sourceautomotive) and connect the two with a piece of high temp silicon hose.
Joe
Old Jan 16, 2007 | 10:40 PM
alright thanks guys
dodgediesel
ABDTR #5
Oct 18, 2011 09:22 PM
dodgediesel
ABDTR #5
496
Oct 16, 2011 04:33 PM
sammy340
Sep 22, 2005 08:30 PM
hotmopr
Feb 7, 2005 09:27 PM
