Twins on a 12 Valve
Twins on a 12 Valve
As you will see in my signature you can see exactly what I am running. I am still experiencing some EGT problems. Could this be due to my fuel plate? What is anyone else running with a 12v with twins and can easily keep EGTs below 1200 going up some steep grades unloaded?
bump your timing to 18 or 19 and make sure your wastegate is opening up all the way. did you drill the wastegate at all? a 1 inch hole saw works perfect for a stock flapper. open your exhaust up too, its 5 inch coming our of the 3b so just keep it 5 all the way back. Ever think of a water/methanol setup? That can help on the long hills and towing. Hope this helps.
dodgediesel
17
Apr 5, 2011 11:21 AM
Stock 02
28
Sep 24, 2006 11:09 AM
stlsparky
Nov 21, 2005 10:02 PM
