Turbo scream with pac brake on??
Ok yesterday all the sudden when my pac brake engaged i get this horrific sound from under the hood.. OMG.. somthing is dieing under there.. so pop the hood and it sounds like my top turbo is dieing...only does it with the brake set... i hammered it today and still gettin 58 lbs of boost so not forsure what this is but it doesent sound good.. i took a vid of it and put in on youtube hopefully the link will come in here..thanks any ideas??
Capn
http://www.youtube.com/watch?v=cbZE9tvAGMs
Capn
Sounds normal to me. Kind of hard to hear though. The brake sounds like any other when it's engaged at idle to me as well. Maybe someone else can chime in and give more information but I'm just not hearing anything unusual.
yea the brake is normal..but about a min into the vid this awfull sound starts..had the brake for a year and the twins since march and never heard that noise before..and when i'm driving and it sets...holy crap.. its really bad!! this isnt normal i dont think??
Whoa. should have listened to the whole thing. I didn't get that far. yeah, I hear it, and that doesn't sound normal to me.. I'm going to let someone else make the recommendations on what to do though..
Sounds like a wheel rubbing to me.
You might try taking the air inlet pipe off the top turbo, pull the turbo shaft towards the front of the truck and turn it to see if it's dragging a wheel on the compressor housing. If it's still quiet & smooth, push it towards the rear to see if it's an exhaust wheel/housing rub.
You might try the same on the bottom turbo too.
A trick an instructor taught me to locate sounds was to take a solid rod or bar, even a broom handle, and hold it to the part you're trying to listen to. Then take the other end and hold it on your ear (specifically the Tragus.... the fleshy part on the OUTSIDE of your ear, when you push down on the little flap it will close your earhole http://en.wikipedia.org/wiki/Tragus_%28ear%29). It'll certainly narrow down what you're looking for.
Capn
Talked to BD and pacbrake today, got different ideas, so guess i need to wait till it warms up a bit, but first thing will be to pull the pipes and look at the wheels, i also have a gasket comin from BD for the wastegate plate on the top turbo which does leak, so i'll get that on but i dont think its a leak! Thanks for all the ideas..i'll be lookin at everything..
Capn
Capn
I'll be watching this thread. Please report back. I have a usgear d-celerator in line and the stock turbo, but after building up some pressure (I think) on a long downhill I started to hear that same sound.
BigBRUNO4
48
Apr 30, 2006 01:09 AM
wvcowhauler
13
Apr 3, 2005 11:39 PM
